| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
What wheels will woork on the 90 yota 4x4?
#2 (permalink) |
some chevy 6 lug rims fit, but the center bore has to be huge to clear the 4x4 hubs on the toyota.....
jeeps use a 5 lugs, not the 6 on 5.5" pattern that the 4x4 toyotas use... there are tons of stock rims for ytas all over the place, check ebay or craigslist.... there is also tons you can do aftermarket in terms of wheels |
#3 (permalink) |
Yeah I need to get some cheap wheels stock size, I have 35"ers and my truck is a little too tall to roll around my garage
http://www.yotatech.com/showthread.p...126#post685126 |
#4 (permalink) |
Bolt pattern 6 x 5.5
CHEVY/GMC YEAR MODEL BOLT PATTERN LUG NUT SIZE 00-04 SUBURBAN / AVALANCHE 2WD 6 on 5.5 in. 14X1.50 YUKON & XL / DENALI 2WD BLAZER / TAHOE / ESCALADE 2WD 69-87 PICKUP 4WD 6 on 5.5 in. 7/16 88-04 K-1500 PICKUP 4WD 6 on 5.5 in. 14X1.50 69-91 BLAZER / SUBURBAN 4WD 6 on 5.5 in. 7/16 92-04 SUBURBAN / AVALANCHE 4WD 6 on 5.5 in. 14x1.50 99-04 C-1500 PICKUP 2WD 6 on 5.5 in. 14X1.50 YUKON / DENALI 2WD BLAZER / ESCALADE 2WD 00-04 SUBURBAN / AVALANCHE 2WD 6 on 5.5 in. 14X1.50 YUKON & XL / DENALI 2WD BLAZER / TAHOE / ESCALADE 2WD 69-87 PICKUP 4WD 6 on 5.5 in. 7/16 88-04 K-1500 PICKUP 4WD 6 on 5.5 in. 14X1.50 69-91 BLAZER / SUBURBAN 4WD 6 on 5.5 in. 7/16 92-04 SUBURBAN / AVALANCHE 4WD 6 on 5.5 in. 14X1.50 JEEP YEAR MODEL BOLT PATTERN LUG NUT SIZE 74-83 J-10 SERIES 6 on 5.5 in. 7/16 74-83 F/S CHEROKEE 6 on 5.5 in. 7/16 NISSAN YEAR MODEL BOLT PATTERN LUG NUT SIZE 72-03 PRERUNNER FRONTIER , P/U , 6 on 5.5 in. 12X1.25 PATHFINDER , HARDBODY 2WD 72-03 FRONTIER , PATHFINDER 6 on 5.5 in. 12X1.25 PICKUP, HARDBODY 4WD 00-04 XTERRA 6 on 5.5 in. 12X1.25 TOYOTA YEAR MODEL BOLT PATTERN LUG NUT SIZE 79-95 PICKUP 4WD 6 on 5.5 in. 12x1.50 93-99 T-100 2WD 6 on 5.5 in. 12x1.50 93-99 T-100 4WD 6 on 5.5 in. 12x1.50 95 1/2-04 TACOMA PRERUNNER 2WD 6 on 5.5 in. 12x1.50 95 1/2-04 TACOMA 4WD 6 on 5.5 in. 12x1.50 00-04 TUNDRA 6 on 5.5 in. 64-97 LANDCRUISER / LX450 6 on 5.5 in. 12x1.50 84-95 4 RUNNER 2-4WD 6 on 5.5 in. 12x1.50 96-04 4 RUNNER 2-4WD 6 on 5.5 in. 12x1.50 As stated the center hole may differ on some of these
__________________
94 4Runner 4x4, V6 Auto, Outlaw II's with BFG 33x12.5x15 on stock suspension (no lift), Kenwood KDC-MVP Sirius/MP3 player, Bushwacker extenda-flares, 1700 watt power inverter, Air intake mod, Radio Shack CB, GPS, Swing arm tire carrier, modified 1st gen Toyota 4Runner Rollbar, Aisin manual hubs, 87 inclinometer, Toyota Brush guard. Where ever you go, there you are. I started out with nothing & still have most of it left. Last edited by Dublin; 09-02-2005 at 09:34 AM. |
#5 (permalink) | |
Quote:
Thanks a millon+1lockNgo |
#6 (permalink) |
Many of the wheels on Dublin's list will not fit properly due to the center hole size and the backspacing as well.
Be aware that backspacing is an issue for IFS rigs. The 85 Toyota 4x4 rims for example will fit on 86 or newer Toyota 4x4s but will stick out, 86 or newer rims will not go on 85 or older Toyotas at all because of the offset - they hit the steering arms. Always best to trial fit one on the front before you buy.
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil Last edited by Flamedx4; 09-02-2005 at 09:59 AM. |
#7 (permalink) |
Flamedx4 is correct to a degree. The factory backspacing on many of these will not work, but as for aftermarket many will. This is only a list of what wheels have the correct bolt pattern. i'm not sure I'd want to have a GM embossed wheel on my rig, but the aftermarket rims I use were ordered for a 98 GMC. The center hub differs on many of these as well, some larger some smaller. with this list and correct measurements of your backspacing and hub size you should be able to go to any yard or wheel shop and get what you need. The center hub could be larger and not a problem, also wheel spacers are availible but personally I don't care for that option.
__________________
94 4Runner 4x4, V6 Auto, Outlaw II's with BFG 33x12.5x15 on stock suspension (no lift), Kenwood KDC-MVP Sirius/MP3 player, Bushwacker extenda-flares, 1700 watt power inverter, Air intake mod, Radio Shack CB, GPS, Swing arm tire carrier, modified 1st gen Toyota 4Runner Rollbar, Aisin manual hubs, 87 inclinometer, Toyota Brush guard. Where ever you go, there you are. I started out with nothing & still have most of it left. |
#8 (permalink) |
I am not worried about looks. I won't have this thing on the road for a few months anyways. It's just that the 35"s make the truck too tall to do the things I need to do to right now. The bracket on my garage door hit the top of my truck this morning.
I just want a cheap set to get me to the shop for an alignment. I would live to find a set of Toy wheels 150-200 price range but i will take what I can get. If I didnt leave my Digi at work i would snap a pic and show ya how close i am to the celing. |
#9 (permalink) |
In that case, there were a lot of 14x6 6-lug rims back in the 70s. Find a set of them!
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil |
#10 (permalink) |
i've got some stock wheels off my 90 pu 4x4 they have tires on um but there not all that great. you can have um fer $100 but i guess ur in fl?
__________________
<>< 98 Taco 2 1/2 lift ect. 4 SALE ~ all from 98 taco: front bumper, stock skid plates, hood bug deflector ~ FOR SALE Pics of my truck |
#11 (permalink) | |
Quote:
I think I am going to scour some bone yards tuesday and see what I can find. Thanks for the offer though. lockNgo |
| Tags |
| 17tacoma, 1st, 4runner, bore, chevy, fit, gen, gmc, hardbody, lug, pattern, prerunner, rims, t100, toyota, wheels, yukon |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| WTB: Frame for short body 84-90 yota truck! | dirtfarmer | The Classifieds GraveYard | 4 | 05-02-2007 06:21 PM |
| my 90 yota | mrtejman | Trucks, 3rd gen-'89 to '95 | 0 | 06-05-2006 10:19 PM |
| Axle/Gear Swap Help: Will a '94 Auto-V6 4x4 axle swap into my '90 22RE-5spd 4x4? | Justin311 | 86-95 Trucks & 4Runners | 15 | 04-15-2006 12:18 AM |
| Help with my 90 Yota 4Runner? | Big Dog's Yota | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 11-29-2005 09:42 AM |
