What type of differential fluid?
I have a 1999 4Runner SR5V6 2WD.
I wanted to change the diffferential fluid and wanted get recommendations for type and grade of oil. What do you recommend?
The owner's manual is a good place to start. It has the grade listed for each of the driveline components.
I'm personally using a Amsoil and Redline in my diffs and transfer case because I've had it sitting around the garage. I'm a fan of synthetics. Any synthetic will be plenty good. Check out Mobil 1 and Amsoil. I've found them the easiest to locate.
MadCityRich
MadCityRich
75/90 or 80/90 weight is fine BUT if you tow or 4 wheel a lot i would really look into a 75/110 or 75/140 weight for extra protection.. preferably a syn in those higher weights.. amsoil, mobile, redline are good ones..
justdifferentials
14
06-11-2017 08:36 PM
Swampwalker
10-12-2015 09:49 AM
Badfish740
09-04-2015 04:21 AM
07, 1988, 2006, 2008, 4runner, change, differential, fluid, forerunner, kind, oil, recommendation, tacoma, toyota, type
