YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 12-16-2006, 08:34 AM   #1 (permalink)
What tires for 3.91 gears?
Just bought a 2001 tacoma and from searching these forums discovered why I am getting such good gas mileage-3.91 gears.
A little dissapointed in the fact I cannot run the american racing 16" wheels I scored on ebay, but with the price of gas I cannot justify changing gears just to run bigger wheels.
All that said, what tires would you reccomend for a 4wd tacoma with 3.91 gears??
naetzker is offline
Sponsored Links
To remove this ad, register today!
Old 12-16-2006, 09:23 AM   #2 (permalink)
KyleT's Avatar
why wont the wheels fit?
__________________
- Kyle
Former Owner of -
1996 Sunfire Red Metallic 4Runner Limited updated 10/31/06
OEM/TRD Lift Kit #1 from Sonoran Steel with 1 Top-out spacer - Lexus GX470 rims - 295/70r17 Nitto Terra Grapplers Yukon 4.88's, E-Locked Rear, Waiting to blow up front diff #2
KyleT is offline
Old 12-16-2006, 09:26 AM   #3 (permalink)
wheels would fit, but from what I have read here the larger wheel/tires would be a problem for the 3.91 gears.
just wondering if theres a middle ground, from the stock 225/75/15, that would not have a negative effect on the stock gears.
naetzker is offline
Old 12-16-2006, 09:51 AM   #4 (permalink)
eric-the-red's Avatar
I run 275/75R16 tires on 16" wheels with 3.73 gears on my 01 4Runner, 3.4 V6 engine. It originally came with 225/75R15. The mileage didn't change all that much, I don't have exact numbers but just going by the distance between fill ups I would say less than 10% drop. I did lose some acceleration, but it wasn't as much as I thought it would be.
eric-the-red is offline
Old 12-16-2006, 05:19 PM   #5 (permalink)
pmbazus's Avatar
Are you sure you have 3.91 gears? I have a 2004 Tacoma with 3.91 gears and the stock tires were 265 70 16 on 16 inch rims. I currently run 265 75 16 tires with a 2.5 inch lift and I don't notice a power loss. If you do have 3.91 gears you are OK to use the 16 inch wheels
pmbazus is offline
Old 12-17-2006, 06:27 AM   #6 (permalink)
Thanks for the advice!
Yup, I think I do have the 3.91 gears. My axle code is B06A, from everything I can find it means 8", 3.91, 2 pinion. Wimpy eh? I do like the great gas mileage though.
pmbazus, do have the V6?
naetzker is offline
Old 12-17-2006, 04:40 PM   #7 (permalink)
pmbazus's Avatar
I have the 2.7
pmbazus is offline
Old 12-17-2006, 04:51 PM   #8 (permalink)
pmbazus's Avatar
Use your 16 inch wheels and get some 265 70 16 tires. Much better.
pmbazus is offline
Old 12-17-2006, 06:55 PM   #9 (permalink)
thanks again!
naetzker is offline
Old 12-17-2006, 07:57 PM   #10 (permalink)
jjrgr21's Avatar
i ran 31/10.50's on a 98' taco that came stock with 225/75/15's, it ran fine for over 200k miles with no issues at all.
__________________
2003 4WD TRD Tacoma
1986 4Runner
jjrgr21 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
33's and a '91 Runner Auto... Gears????? AuburnRunner 86-95 Trucks & 4Runners 18 03-15-2007 06:50 AM
Will 15" wheels & tires 31 x 10.50 R15 from a 91 4runner fit on a 91 Land Cruiser? weezy 95.5-2004 Tacomas & 96-2002 4Runners 5 06-18-2005 07:45 PM
Tires, lift and gears??? Wildfire 95.5-2004 Tacomas & 96-2002 4Runners 2 08-24-2004 06:19 PM
gears and tires Mikeys87 North Carolina 21 04-21-2004 03:03 PM
gears/tires maddmatt02 95.5-2004 Tacomas & 96-2002 4Runners 32 03-15-2004 09:20 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
