What is this switch in my fuse box?
Old 08-03-2010, 02:04 PM
JBurt's Avatar
I found this when I opened the fuse box. I don't know what either the black box or the switch with in the bottom right corner is. The joy of used vehicles. At least it runs really well. Thanks in advance.
Old 08-03-2010, 02:06 PM
y2kltdsport's Avatar
helps if you got a pic......just sayin'
Old 08-03-2010, 02:07 PM
yotamonsta-'s Avatar
Maybe some kind of alarm!!!!
Old 08-03-2010, 02:08 PM
o.k. now the pic shows up after I send my message... oh well, it looks to me like aftermarket alarm or something??
Old 08-03-2010, 02:59 PM
Bird-Doggin's Avatar
I had a 98 Taco that had an alarm with a toggle switch. I never had the key fab to activate the alarm and never really understood what the toggle switch would be used for. Is there a siren under the hood? If so, try and follow the wires from the siren to the black box.
Old 08-03-2010, 03:01 PM
Elton's Avatar
switch is for the valet mode yes looks like some poor cheap alarm
Old 08-03-2010, 07:45 PM
Kerby J's Avatar
x2 on the alarm and the switch is for the valet mode if i were u just go and take it out bc it will b useless without the key fobs
Old 08-03-2010, 07:46 PM
Ron Helmuth's Avatar
that's an Improvised Explosive Device sir! run away
just messing wit ya dude
previous owner took some time to fit that in there.
Old 08-03-2010, 08:27 PM
rideexileex's Avatar
Could be a cheap remote start too - they often come with a switch to enable/disable the start feature, but shops hardly ever actually install it. It's a 'safety' thing...
Old 08-03-2010, 08:31 PM
JWaldz's Avatar
I'll go with D) All The Above. Regardless what it is thought, it seems to be quite pointless...
Old 08-04-2010, 07:33 AM
Mauzer's Avatar
It def looks like an alarm brain box, if you can get a model # off the box you can get a fob for it. I was in a similar situation and turned out the PO had a DEI remote start alarm installed but lost the fob so they disabled it before they traded it in to the stealership. I got a new antenna and fob and now I use it daily....love the remote start in this TX heat!
Old 08-05-2010, 11:59 AM
profuse007's Avatar
Older model Prestige or Audiovox alarm w/ toggle switch valet. These days, all valet buttons are push buttons.
Old 08-07-2010, 07:43 AM
JBurt's Avatar
Thanks for all the help and ideas. I thought with it being saturday I would have some time to tear into it today. Now the wife wants to go into San Diego (2 hrs away). Also good but not would I would have picked. I'll let you guys know more later.
Old 08-07-2010, 09:20 AM
rumrunner6907's Avatar
that was george bushes old vehicle he had it installed so he could blow up nations while at his ranch lol
Old 08-17-2010, 09:34 PM
JBurt's Avatar
So it definitely is a car alarm. The brand is KARR. I can get the fcc id but I cant find the model number. I'm assuming that the switch is for the valet mode. I had the battery disconnected while I was doing some other work and now whenever I hook up the battery the alarm goes off. I don't have the fob and putting the key in the ignition/door doesn't turn it off. If there is a write up on how to take them out I would be happy to go that route. Right now I would just be happy to get the alarm off and my truck started.
Old 08-17-2010, 09:45 PM
85gijunk4x4's Avatar
lol, im gonna subscribe, so i can see the pic haha jk
Old 08-17-2010, 09:46 PM
ohh i see it now, im not sure what it is.
Old 08-17-2010, 09:47 PM
ohhhh...my bad...you already found out what it is...
Old 08-18-2010, 07:41 AM
Mauzer's Avatar
if you have the FCC id just buy a fob for it here:
http://www.remotesandkeys.com/search...s.asp?cat=4256
no sense in un-installing it if it obviously works, just pull the fuse till you get the fob (unless that trips the kill switch)
Old 08-18-2010, 10:26 AM
Kerby J's Avatar
it will only trip it if it has battery backup which the control module doesnt look like its big enough to house it
Quick Reply: What is this switch in my fuse box?
