What spring for Bilstein front adjustables?? (02 Runner)
I'm consider purchasing a set of Bilstein front adjustable shocks but am having trouble choosing which spring I should go with. I have a badlands bumper on the front at about 100lbs. The cheaper the better so if something OEM Toyota would work that would be great. I think Sonoran Steel uses one from a Tundra. Can anybody confirm this or recommend a spring? Any help would be great.
Id say OME 881's or 882's..
I think the 882's would be more suited to your front end with (guessing you have a V6) and your front bumper..
TRDparts for you has a great sale on ome springs right now, I payed 361 shipped for 881's and N91S's...Which btw is a GREAT price..
Check it out..
Oh btw, Toyota is gonna charge you out the rear end for springs..
Check it out..
Did you notice Steve has a front end package already put together?
http://www.sonoransteel.com/store_co...ml#Tacoma_Lift
Scroll down just a bit from where the link starts you off.
Or are you hoping to cobble it together a bit cheaper?
me? Sure did, That was the first lift I was looking at when I got my taco...
steves lift is 650,
2x what I payed and ill prolly get a lil more lift..
I only payed 361...
steves lift is 650,
I only payed 361...
No I was addressing the OP. It appears you have already made your choice. I would just like to point out to the OP to read Sonoran's FAQ (just a little further down the page that I linked). Specifically #s 8, 11, and 12. Make of it what you will, I just like to have as much info as possible before a purchase. Also, keep in mind the OME setup isn't adjustable. Best of luck.
Check out OME 882's. I have them and really like them so far. They're work especially well on 3rd gens with a heavy bumper, but I'm running them with my stock bumper and got right at 3" of lift on my '02. You'll probably get less lift with your bumper, but they will do well with the Bilstein shocks.
Thanks a lot guys and yes I have seen Steve's setup. For around $700 shipped I could almost go coilovers so you are correct BLK, trying to save some money!! Steve does make excellent products though.
The reason I was asking about Toyota factory springs was because I could probably find a used set pretty easy and cheap. Does anybody know if the OME springs are the same height as stock ones or what?? Just trying to make sure I don't get too much lift from the Bilstein/OME setup.
I would avoid using stock springs with this setup, especially used ones. They have thinner diameter coils and a reduced spring rate, which will lead to sagging over time. The OME coils have a 500 lb. spring rate and .63" diameter coils and most likely will not sag, no matter how long they're on.
The OME 882 coils are considerably longer than stock. In fact, if you're running a shock with stock travel measurements and full extended length, they won't fit. I'm not very familiar with the Bilstein adjustable shocks, but I would think they'd work fine with the 882's. With that setup, you'll want the lift to come from the springs, not the shocks.
Thanks EP. I'm sure the factory springs would work fine if I could just find out which ones Steve at Snonran Steel uses in his setup. He has done so much testing that I truly believe he knows what is best. I know it's from a tundra so it should be designed to carry more weight anyways.
I would like to use the OME's but just don't know where I need to set everything up when assembling them to get the right height for my lift. Maybe someone will chime in.
It'd probably be worth giving Toytec a call considering they sell the same shocks...
http://toyteclifts.com/index.php?opt...t&limitstart=0
I swapped out my stock 06 tundra shocks for a set of adjustable bilsteins with stock springs and love them. The valving is perfect sway control is much improved steering response is better and I got a 2.5 inch lift. I know this is a different vehicle but my suggestion would be try out the shocks with stock springs first, then if you think you need more do some research on springs. Just my 2 pennies
The second number is real far off.
Why does Rocket hate so much?
Thanks Steve but don't you guys use the Bilstein adjustable on Tacoma's as well?? Isn't the shock the same part number for both Taco's and Runners?? Any help would be great.
Look at the shocks body itself, much larger, 5 adjustment settings, not 3 and finally the lower bushing is much larger. Inside is custom valved to what we found to be ideal. Extended length was spec'ed out too.
I had to buy a very large quantity of these to get them made.
Gotcha Steve. Makes much more since now.
We do use the same custom shock for both the 4Runner and Tacoma. The shock we use IS NOT the Tacoma specific Adjustable shock. It was one made specifically for our setup.
88Toy
7
06-17-2015 09:40 AM
XtremeOff-Road
13
11-16-2003 02:31 AM
