| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
What.s your RPM ? ? ? ? ? ? ? ? ?
#2 (permalink) |
My rig is different, but I'll give ya a bump...
Stock tires, tranny and diff. 3.0, 4.55's, 31's, and 3000 @ 70
__________________
'99 4Runner SR5 4WD, 5-SPEED. Abzug's vehicle for urban expeditions, navigating flash floods and debris flows (try 12-15 inches of rain in one week). It always gets her home. '95 4Runner LIMITED 4WD, 5-SPEED, over a quarter million on the original 3vze & headgaskets. TRD heavy duty clutch, TRD heavy duty flywheel, OME 900 springs and shocks. This old gal has gotten me out into the field, and back for 8 years, never failed to start or gotten stuck. |
#3 (permalink) |
My '90 (3.0/5sp) with 5:29s and 35s reads 70 at 66 (actual-timed) and does 2800 rpm at 66 actual)
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil |
#4 (permalink) |
I have 4.88s and 33s but prety much the same as above (3000rpms @70 miles per hour)
__________________
Will WabFab Off-Road, LLC Toyota 4x4 Parts and Custom Fabrication updated website with lots of new products 87 runner with every bolt on available |
#5 (permalink) |
I posted this info awhile back.....here it is again
-------------------------------------------------------------------------------- WooHoo! I just had new 4.88 Yukons installed in my '84 truck...sweet! With the 33" tires, the gearing is just about perfect. I can use 5th on the freeway now! Some notes to share: On the freeway, speedo seems to under-read speed by about 5 miles per hour. When speedo says I'm doing 65, I'm doing closer to 70 (assuming my wife's Honda speedo is accurate). In 5th gear: Tach says 2600...speedo says 60 Tach says 2900...speedo says 65 Tach says 3300...speedo says 75 In 4th gear: Tach says 2500...speedo says 48 Jim
__________________
'04 4X4 XTRA Cab SR5 V6 TRD Automatic..Sweet! '84 4X4 Standard Cab 22R 5-Speed Pickup..SA! 33X12.5 BFG-AT KO's**4.88 Yukons**Budbuilt Crossmember**OME Springs**Badland Bumpers, Sliders**Sky shock hoops**Bilsteins** |
#6 (permalink) |
Guest
I was thinking about writing a small webpage where you can select model year, transmission type, tire diameter, gears, and miles per hour... then it would spit out the RPMs in each gear.
The math behind it is incredibly simple. |
#7 (permalink) |
I was just looking at my rpm's on the interstate the other day, at about 74 I was right at 3000rpm's.
anyone else have a 5spd 3.0 with 4.10's and 31's? I'm curious if my tach is correct,.
__________________
89 Deluxe Short Bed, 3.0 V6 5spd, 4x4, 31x10.5 BFG Radial Long Trails on 15x8 Pacer rims, K&N air filter, high flow cat, Dynomax 2.5" Super Turbo muffler, Sunpro tach... Fiamm 125db. low note horn Pioneer 50w x 4 cd player, Polk speakers |
#8 (permalink) |
Pretty hard for the tach to be wrong. Did you mean speedo? <grin>
Very easy way to check your speedos. Drive the freeway at a steady speed. Pick one, 55, 60 65, etc. Set your stopwatch (or have someone watch the second hand if you're digitally challenged) at a mile post. Time at least 3 mileposts to get a better sampling. (they are NOT very perfectly placed...) Time at 60 miles per hour will be 60 seconds per mile. 55 miles per hour is 65 seconds, 65 miles per hour is 55 seconds... get it? Seeemple.
__________________
#9 (permalink) |
Changing your tire size and differential ratio won't affect the relationship between your tacho and speedo, because the speedo is driven off the transmission, so unless you change the transmission ratios, that relationship is constant. Changing tires and differential gears will change your ACTUAL speed at a given RPM.
#10 (permalink) | |
Quote:
if those things the cops set up to tell you how fast you're going are correct, then my speedo should be right on. man I'm itching to get bigger tires and a lift too, but my wallet says that won't happen anytime soon =p
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| What RPM | toy4whatever | 86-95 Trucks & 4Runners | 3 | 12-11-2006 11:17 AM |
| Rpm Gage | Mexifoo | General Electrical & Lighting Related Topics | 0 | 12-10-2006 01:01 AM |
| RPM Problems!!!! | NX Tacoma | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 08-24-2006 05:20 PM |
| Rpm | "Cat-O-Leen" | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 03-31-2003 06:24 PM |
| A/T Shift RPM | az4x4runner | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 12-14-2002 08:05 PM |
