What is the purpose of this?
Old 08-24-2012, 01:12 PM
sampsonite987's Avatar
Hello everyone, first time poster.
'97 4Runner 4X4 SR5
Ignoring the fact that this is one of the worst DIY attempts I have ever seen, what would be the reason for this? There are what appears to 2" coil spring spacers installed, so my first thought was they were attempting to extend the end links because of the lift (not that they are of any use in this state though). Any other reason this may have been done?
Old 08-24-2012, 01:27 PM
motocrossaddict223's Avatar
If thats your sway bar, it could be a disconnect for it to allow for more articulation. That being said, i dont know what part thats on so i could be wrong. Is it on both sides?
Old 08-24-2012, 01:46 PM
It is the sway bar. Same on both sides. If it was a disconnect, why have it extended 2.5 inches above the factory end link? Seems to me the sway bar is basically pointless after that "mod".
Old 08-24-2012, 02:12 PM
I dont know, wish i could tell you but i didnt do it. Maybe its supposed to slide down 2.5 iinches or something
Old 08-24-2012, 02:25 PM
Blown96's Avatar
Well I thought I was the only person that was that home grown on here. Tire bushings are a classic. That being said will it in screw up top? It looks like the thread has been welded below the sway bar
Old 08-24-2012, 02:29 PM
cubuff4runner's Avatar
It looks like when they lifted it they thought that the swaybar links needed to be extended. The swaybar will still work, but the lack of bushings and theall-thread link is probably going to snap sometime. I would get a set of disconnects.
Old 08-24-2012, 03:32 PM
SCToy's Avatar
Maybe to compensate for a bracket lift? Looks like those 'extensions' would snap of quite easily though.
Old 08-24-2012, 04:08 PM
James Woods's Avatar
Wow, now that is some jimmy rigging. I don't why they went through all the trouble, I just removed my sway bar when my end links went bad on my 3rd gen, hardly even know its missing.
By the way your inner axle boot is leaking.
Old 08-24-2012, 04:35 PM
stockwell45's Avatar
Jeez, that almost scares me as to what else could be "tweakerfied" on your 4runner. I'd check everything in the engine compartment and do a full sweep of everything on the undercarriage after seeing that.
Old 08-24-2012, 05:57 PM
Stu Pidasso's Avatar
Would that be proprietary?
Old 08-27-2012, 05:32 AM
Haha, some good responses guys. I have seen my fair share of redneck engineering, but generally those fixes at least somewhat accomplished the desired result. This not only looks terrible, but would be worthless if I really needed the sway bar. Granted, if I were in a situation where I really needed it, some other awesome engineering marvel that I haven't found yet would probably give out and send me rolling into a ditch.
Old 08-27-2012, 05:41 AM
waskillywabbit's Avatar
Commonly known as booty fab.
Remove and replace.
I sell endlinks and discos for lifted 3rd gens so you can do what they attempted to do correctly.
:wabbit2:
justdifferentials
14
06-11-2017 08:36 PM
Badfish740
Diesel Swaps
12-09-2016 06:18 AM
A2theK
09-30-2016 12:50 PM
Toys4parts
09-26-2015 01:56 PM
dammitcam
09-10-2015 02:37 PM
Quick Reply: What is the purpose of this?
