| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Where is my coolant going???
#2 (permalink) |
that looks to be around the tcase or tranny... sure its water and not some type of oil... how is the condition of the exhuast? it could be a number of things.... might even be a freeze plug on the engine, but those pics look too far back for that... maybe an auto tranny cooler line?
#3 (permalink) |
That is the transfer case.
__________________
94 4runner SR5, V6 3VZE, 5 speed Completely rebuilt engine with Toyota parts at 147k miles Downey Coils, Aisin manual hubs, Cowl Louver mod, Hella 500 fog lights Yeah, I know, not many cool mods here Last edited by runethechamp; 11-07-2005 at 12:33 PM. |
#4 (permalink) |
First you should definatly get a new sending unit!
Second that looks like it could be comin from the rear heater (which has two coolant lines running to it)
__________________
poop 1988 stock 4runner, v6, 5spd, soft top. 1990 fj62 stock and mint! 1992 4runner, 3.4, auto, SAS'ed, Marlin USA springs (4"/5"), 37" PBR's, 30 spline Longfields, Hydro assist, dual inchworms (5:1, twin stick, 23 spline, chromo output, 10* clock) 5.29's, lockrite's, custom exo, High angle drivelines drive shafts, 108" wheelbase, Warn hs9500i, Mcintosh/Dynaudio a/v system. The build up...http://www.yotatech.com/showthread.php?t=74915 |
#5 (permalink) | |
Quote:
What should I do??? Pull the center console?? |
#6 (permalink) |
the center councle is 4 srews should take about 30 seconds. then you can see if its leaking from the heater or a fitting, you can pull the heater very easily too.
__________________
#7 (permalink) |
I am trying to pull the console. I can move it freely about an inch vertically, but cannot comletely remove it from between the seats. Should I use the force??? Do I need to unhook something I am not seeing?
#8 (permalink) |
You have to disconnect the two rubber hoses that come up to the heater core from below. Likely cause of the leak is the rubber lines themselves, that's where mine started leaking.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#9 (permalink) |
Your pic is of the transfercase. The line that comes out the rear of it goes to a cooler for the fluid in it. Its a shared tranny fluid hydrolic controled unit.
Ive known people to have a radator that is starting to leak, but only under pressure, so because the fluid is underpressure(higher temp) as soon as it leaks it evaporates. leaving no drips or puddles. (like a seam on the radator is starting to fail) The heater hoses at the rear are also suspect, Mine leaked at the rear, which dripped down the back of the hot block and evaporated. never really formed a puddle till the hose compleatly rotted off on the interstate...
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers 92 4runner, auto, V6, OME suspension, Downey headers |
#10 (permalink) | |
There are no visible holes in the lines to the rear heater, but they are pretty corroded and soft and have a lot of buildup on them.
Quote:
#11 (permalink) |
Also check the j-tube at the rear of the engine, in front of the firewall. It's a tiny little hose, but it leaks sometimes, like any hose.
I'd also suspect the casting plugs mounted at the point where the engine meets the tranny...as in you can't see it without removing the tranny. There are 5 little brass casting plugs that can corrode and seap.
__________________
91 4Runner, 5 spd, with the Mighty 3.0! 0 to 60 in 2.5 liters. |
#12 (permalink) |
Where does the metal pipe go that the j-tube connects onto? I have leak in mine and I would like to try to replace it with a rubber hose, however I cannot see where it goes.
#13 (permalink) |
anyone know?
#14 (permalink) |
the ones that rotted out on me were on the rear of the motor, the water bypass outlet
![]() see the http://personal.utulsa.edu/~nathan-b...68cylinder.pdf for the entire thing
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Complete Part Out: '96 4Runner Limited - Part 2 W/ Pics! | 914runner | The Classifieds GraveYard | 89 | 12-31-2007 07:53 AM |
| Weird cooling issue w/ 22re | boostaddctn | 86-95 Trucks & 4Runners | 8 | 09-25-2006 01:01 PM |
| Spare tire lift - part 1 complete, need HELP with part 2! | tc | 86-95 Trucks & 4Runners | 7 | 01-03-2006 07:03 AM |
| OD issue, I have 2 part numbers and dont want to order the wrong parts! | Ilovemountains | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 11-15-2005 11:05 AM |
| Weird cooling issue. | 88RunnerV65Spd | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 11-19-2004 05:05 PM |
