what is this part?
what is this part?
what is the shifting key spring? my transmission grinds gears every now and then even with the clutch all the way in still. I was looking in the FSM and is suggested a worn shifting key spring. i searched and googled it but didnt find anything that helped. can someone explain what it is and tell me if this is what is causing my problem. if im careful and shift it slow it seems like i can find a spot when moving between gears that makes it not grind. The plastic bushings are also good, they look new.
Hummm. Don't know for sure. You are referring to the "seat and bushing" in the shift tower mechanism that is good? That's what I was first thinking when I read your post. If that is okay I'd take a good luck at your clutch hydraulics. Is your slave cylinder puking fluid? How about your master cylinder, don't forget to look at the back side. What does your hydraulic fluid look like? Maybe your seals are shot and you are bypassing. Is your clutch dragging at all? That is, do you have an adjustment problem? Something bent or broken? Release bearing not binding? Just some thoughts.
Also, take a look at your transmission fluid/oil. Is it clean? Is there any indication of brass or bronze in the oil? If so your syncros may be starting to go out.
-Wrench
-Wrench
The spring you are talking about are I think the springs on the return bearing hub. They are the little clips that hold it to the fork. I know mine came of and my clutch did that. I had to pull the motor and put them back on. Just a guess tho cuz i had a similar problem.
i just replaced the clutch, throw out bearing, fork and pilot bearing. my slave cylinder doesnt leak and i have bleed it. it is also adjusted right too. my tranny makes a squeling sound tho right before its hard to shift or grinds, i can tell if it is gonna give me problems if it is started to make a sound.
FS[GreatLakes]: 22RE performance and stock parts (pic heavy)
05-20-2016 10:27 AM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
