Old 04-21-2016, 03:20 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Tire Repair and Maintenance
Print Wikipost
what P.S.I. do you fill to?
Old 08-14-2003, 10:38 AM
amorphous's Avatar
Checked my tire PSI yesterday, I dunno WHAT i was thinking...I was running it at 35 (same as my wagon) - so I bumped it up to 44 PSI (45 is max on my GY mt/s 's) This should bump my mileage up a bit for 'round town/highway
my question: what PSI do you keep, and on what tires? On road PSI? Off road PSI?
thanks,
Aaron
Old 08-14-2003, 10:40 AM
L33T35T 4Runner's Avatar
i you need to lower that quickly. i ran at 38/40 front/back for a while, and now i have over inflation on my tires. i am now running 32 all the way around.
offroading i'll lower it down to 15 to start off with, but that honnestly doesnt do much, 12 is a good place to stop for mild offroading.
for the sand.... I go to FOUR psi
oh ya, i have goodyear wrangler GSAs
Old 08-14-2003, 10:43 AM
Tacoma Dude's Avatar
yeah, there was a thread about this a few months ago... I think everyone was in the low 30s.
I inflated to 35 after Pismo but that was warm... I'm going to be checking it out when it's cold and try to get myself to 33 all around.
Old 08-14-2003, 11:01 AM
amorphous's Avatar
thanks for the info guys - i don't want no fork'd up tires, better lower that then!
~a
Old 08-14-2003, 11:07 AM
romus's Avatar
33 psi for me on all 4 tires
Old 08-14-2003, 11:11 AM
Mad Chemist's Avatar
32 on all four
Old 08-14-2003, 12:20 PM
AznSky's Avatar
I run mine at 35 psi. 15 while offroading in mud and on rocks.
Old 08-14-2003, 12:21 PM
rimpainter.com's Avatar
35 here.
Old 08-14-2003, 12:29 PM
Paul H.'s Avatar
35 rear, 32 front.
Old 08-14-2003, 01:43 PM
Churnd's Avatar
Originally posted by <96 Runner>
35 here.
ditto.
Old 08-14-2003, 01:49 PM
Woodbert's Avatar
35 for me as well on Dunflop 265-65-17 AT20 for now.
I'm waiting for my Dueler AT Revo 265-70-17's to come accross the pond.
Old 08-14-2003, 02:05 PM
Bumpin' Yota's Avatar
47psi here, max is 50. No tread wear problems either.
Air Shocks sitting at 125psi. (~625lbs of lift) and the rearend is a touch higher than the front end.
~350-400lbs of audio gear in it right now....
Old 08-14-2003, 02:17 PM
Churnd's Avatar
Old 08-14-2003, 03:14 PM
Glenn's Avatar
Yikes. How's the ride?
Old 08-14-2003, 03:49 PM
HBoss's Avatar
I second the:
I run 32 all around as well.
Old 08-14-2003, 04:50 PM
OneTrickToy's Avatar
As for what I know with my limited knowledge, each vehicle is different. But what you want to do, is have a flat footprint. You want the flat part of your tread, even across the pavement. And as long as you do that and you are under the maximum psi, then you should be fine. What I question.... is the higher psi in the rear as compared to the front. There is more weight in the front of the vehicle(engine), so theoretically(I've noticed this with my truck anyways), you need a higher psi up front and lower out back unless you are towing or loaded up with lots of weight. I've been playing around with my tires trying to find the right spot so that I'm getting a clean footprint. I'm running about 3 psi higher up front. I'm at 40/37 at this very moment.
Old 08-14-2003, 05:01 PM
Fink's Avatar
32 all around here
Old 08-14-2003, 05:14 PM
Not bad actually, but then again I'm used to how a 1-ton pickup truck rides, lol. I have one of the heavy ass (or ass-end heavy...lol) 2nd gens. Curb weight is like 3984lbs accourding to my registration slip.
I am getting that ideal flat footprint as well.
Haven't had to air down for any offroad stuff, but I dont go offroad a lot either...
Old 08-14-2003, 05:17 PM
Guest
Yoter's Avatar
Hey guys what about 35 inch 50 PSI rated tires. Why do the shops only fill them to 30 to 35 PSI. They always look low to me.
Old 08-14-2003, 05:21 PM
That's cuz they are likely low.... But they probably do it in accourdance to what the slip on your driver's side door jam states. That's typically the case after Sam's Wholesale installs my 50psi rated, 6plys. Go fill em up to ~45 and check how they are wearing after 1k miles. All of the beads lines should be wearing exactly evenly - you can use a micrometer's depth gauge to determine each beadline's heighth.
Steve
Quick Reply: what P.S.I. do you fill to?
