What is this noise
What is this noise
Alright, flame me later for this newb question but as usual I searched and every topic was non-related. I havve this whine, similar to a PS whine, that increased with RPM which I thought for sure was the TBelt. Had that replaced, which turned out to be a good thing since it had a stress crack along its width, but the noise persists. I see no leaks on the PS unit and the fluid appears normal. What could be the cause? It's not a high pitched whine but more of a groaning whine (wtf?) THe sound doesn't change when I move the steering wheel, only as the RPM increases. I have no loss of power either. I remeber it started on Coyote Canyon (SoCali) in one of the rock gardens. Any ideas or suggestions would be appreciated. TTORA hasn't let me down yet.
What I really need is someway to get a soundbite on here so diagnosis would be easier.
Thanks in advance..........
I have an annoying whine as well that increases with RPM. I used the poor man's mechanic stethoscope and the noise is clearly coming from my alternator. I'm guessing it can be a worn out alternator bearing or a damaged diode in the rectifier.
At idle, the whine gets noticeably louder with increased electrical load such as turning on my low/high beams and fog lights.
Not the case with mine but I did come across this video of someone that apparently fried their AC compressor bearing after some water crossings.
http://s8.photobucket.com/albums/a2/...t=MOV02712.flv
This is the identical noise mine is making and come to think of it when I crossed the third water crossing at Coyote Canyon the water was coming over the hood and I may have very well fried the AC bearing at that time.
i have the exact same noise, i drove through a street with about 4ft of water, mine has been doing this for about 6 months, the ac is cold, but annoying as hell, can you replace the ac compressor bering.
Was this groaning noise present before you had that t-belt replaced?
If it occured after, it might be a good possibility that the t-belt tensioner is putting a little to much tension on the t-belt.
Mike
_______________________________
85 Toyota p/u 4X4 std. cab
(too damn powerful)
99 Toyota 4-runner 4X4 (wifeys)
E-locker, 4:56, std.
69 Jeepster commando 4X4
(27k original miles) my daily driver
Mike
(too damn powerful)
(too damn powerful)
(too damn powerful)
And the t-belt sang a song... i think the noise is called harmonics. i just tried to take-up a little bit too much slack in the belt at the tensioner itself.
And i was'nt about to take the tensioner all back out again cause' one of those bolts are a pain to get to.. ha!
But the jobs done and there's goes another happy toyota owner!
Here's a peek of the job in progress.
I am having a similar issue. Only mine ONLY happens while in gear D, 2, 1, or R. It increases with RPM. I flushed my tranny 2 weeks ago and it seems to have started then. I haven't noticed any problems shifting or anything like that. Should I be worried? My mechanic told me to try some Lucas Transmission Additive...didn't help. Since it only happens in gear, I am guessing it is the torque converter? Any ideas?
zytra
01-24-2019 03:16 PM
zombie_barbarossa
10-02-2015 10:54 PM
