what kind of battery?
i was just wondering what kind of battery you all are using, how much and maybe where you got it? i'm looking to buy a new one soon. i don't need anything to special, just something that can handle some small extra draws and the cold.... thanks
I run a winch, lights, stereo amp, and other stuff and I will never buy anything other than Optima. I've had a red top for four years now and never had a problem. I'd buy an Optima even for a passenger car or if I wasn't running accessories, just because of reliability. IMO, Delco maintenance-free is the worst battery.
Get a red top with gold terminalls. This combo will give you the best performance possable and you will never have to clean your terminals again!
My red top:
My red top:
Hey miles! That's exactly what I'm gonna be doin over spring break, rewiring my whole rig...fog lights, driving lights, system and battery terminals. What all do you have goin on there? I will be upgrading my ground and hot terminals and then running to a distribution block, maybe an aux. fuse box but I haven't thought about it yet.
Miles is right, rewiring it is the way to go!
Fink
Fink
Chris, -->I havn't re-wired the charge wire or main positive yet because it is so small and such a pain in the kester but I have done some major gournd wire upgrades. I ran several just to be safe. The 4g one in the pic goes to the block and I have since added 3 other 8g that go to the body/frame. Mabe when I do a motor swap I will upgrade the rest of the wireing. The 4g red wire is for my amp.
Optima red top.
miles,
Thanks man, I will probably end up doing it the same way over spring break...what all would I need, like where should I get the terminals and all that stuff, I can probably get the wire from like Lowe's or use car audio wire or something right?
So does the terminal that you have for the ground have different slots for several different wires, as in like I can use the same terminal connected directly to the - post on the battery and just run different wires from there or do I need another spot to run the wires from? Thanks man!
Fink
Fink
jasonty
41
12-23-2018 01:00 PM
greasyglue
12-12-2015 12:57 PM
Peevedkitten
11
08-31-2015 06:57 PM
dropzone
08-11-2015 05:16 PM
