what gears to get??
Old 02-17-2004, 09:00 PM
grafix43's Avatar
what gears to get??
i have a 94 22re auto... i have 33 in tires, with like 5-6" of lift total.... what should i re gear to? 4.88's? and who sells the gears for cheap and what brand etc... sorry i dont know much about this yet... thanks - steve
Old 02-17-2004, 09:32 PM
Serith's Avatar
I got a couple of questions for you:
1. 5-6 total inch of lift? with only 33's? seems a little much, got a pic of your truck?
2. do you plan on going with bigger tires in future?
If not, than i could THINK 4.56 would be fine, but i'm not quite sure. as what "brand" i do not know, sorry.
Old 02-17-2004, 10:31 PM
grafix43's Avatar
i know it has body lift of 2 inches, i think the suspension is 3 or 4 inches... it has rancho shocks i saw that... i dunnjo cause i bought the truck the way it is... im planning on staying with 33's just maybe muds soon..... anybosdy know what i should do gear wise? - steve
Old 02-17-2004, 10:48 PM
Brendan's Avatar
4.88s are the proper gear ratio for 33" tires, but if you ever decide to go to a 35" tire, you will regret not going with 5.29s. consider a locker will you have the third member out to change the gears. as for brand, i'd look at US gear or precision gear.
Old 02-18-2004, 05:01 AM
CTB
CTB's Avatar
Man, a 22re automatic with 33's and stock gearing...have any trouble getting up to speed?
Old 02-18-2004, 06:50 AM
beachtaco's Avatar
i bet your axle code is G252 which means 4.56 gears. i had the same setup on my 92, 22re, auto, and 33". it was slow as a dog. i would recommend 5.29 that would bring you back close to stock.
try west coast differentials. alot of my friends had good things to say with them. and then there is all pro offroad. avoid randy's ring & pinion, my friends had alot of problems getting gears from them. as for brands, i'm not sure. you only need the 4cyl gears but if you can afford some, you can upgrade to a v6 diff housing with v6 gears. they are stronger.
Old 02-18-2004, 07:51 AM
Brendan's Avatar
where do i look for my axle code?
Old 02-18-2004, 08:39 AM
Flygtenstein's Avatar
If it is a runner, get 5.29's
I suppose that is the same answer if it were a truck since it is an auto.
I run 33's with 5.29's behind a V-6 and auto. It is great.
I would also recomend getting larger tires or less lift. You should be able to fit 35's with at much height.
Old 02-18-2004, 09:38 AM
grafix43's Avatar
i was thinking about going with 35's cause im pretty sure i can clear them... put them wouldnt it be even slower? i actually dont have tooo much trouble getting up to speeed.... but then again my speedo is off so it only seems like im going faster..... so i take it either way with 33's or 35's, 5.29 is the right gear to get correct?
Old 02-18-2004, 08:25 PM
Cebby's Avatar
I vote 5.29's
Old 02-19-2004, 08:30 AM
grafix43's Avatar
got a new question for you guys... i called west coast differentials and they said the rear gear set was 140$ or so, front was like 106$, and each installation kit was around 100$ or so..... what is the front for? i thought i just needed to change the rear gears in the differential? im still learning so if u guys could explain that would be great.... also should i buy the install kit/kits if i plan on having a shop do it for me. - steve
Old 02-19-2004, 08:47 AM
sport's Avatar
The gears that you are changing are in the differential (on the axle). You have to change both the front and the back so that they both rotate at the same speed. This is why it cost so much. Also, that seems like a very good price for everything.
Sport
Old 02-19-2004, 08:57 AM
anthony1's Avatar
You have a 4x4 right? there's two differential, one in the front, one in the back.
5.29 is right for your auto transmision.
Make sure you take it to a place that knows how to regear.
Old 02-19-2004, 09:00 AM
44Runner's Avatar
only if you never plan on using 4 wheel drive. if you only gear down the rear then your front will spin faster than the rear when 4wd is engaged. That binds up the driveline badly...
Old 02-19-2004, 09:11 AM
victimeiced's Avatar
wow is it really that cheap to regear???
i was under the impression it was a $1000+ job. I'm in the exact same situation: 94 4runner v6 3.0 Auto, 6-7" of lift, 33''s for a year or so, then up to 35''s. So go with the 5.29's right?
Old 02-19-2004, 09:13 AM
anthony1's Avatar
That's just parts dude. Labor is about 250 per diff.
Old 02-19-2004, 09:42 AM
44Runner's Avatar
for quality gears you're looking at 190 per set, plus 145 for a quality install kit (you need two), plus about 200 per diff in labor. So you were right...
Old 02-19-2004, 03:35 PM
Fahrenheit 451's Avatar
Don't the automatics come stock with 4.88 gears?
Old 02-20-2004, 06:47 PM
grafix43's Avatar
i failed to mention in this post that i have 2 wd... so does that mean now i only have to buy the rear diff only cause its only rwd.... lemme know - steve
Old 02-20-2004, 07:11 PM
mt_goat's Avatar
The auto's with the factory 31" tire package did.
Quick Reply: what gears to get??
