What gears do I have??
2002 4runner...complete base model SR5 2 wheel drive.
One sight is saying 3.73s and another guy is saying either 3.90, 4.10, or 4.30.
I need new gears but can't decide because I don't know what size stock I have!
- Chris
- Chris
I would check car-part.com and go with 4.10's or 4.30's
you can find a used third on that site and just swap it in. I am betting you have 3.90.....
you have the v6 right? if not go with 4.56's
yeah v6 automatic trans. ring n pinion guy is suggesting 4.88s for a DD and thinks I have 4.10s. spec sheet on the internet is saying 3.73s. called dealer with my vin and is saying 4.10s or 4.11s
- chris
- chris
4.88's v6 = 35's
4.56's v6 = 33's
I personally believe you would be way overgear'd with 4.88's on the street with 32's......
Are you going to go any bigger than 32's?
I am running 4.88's with 33's, but i am the 4banger and its a very good combo.
4.56's v6 = 33's
According to this spec sheet:
http://www.top4runners.com/ja/runhis.../2002specs.pdf
2WD AND 4WD WITH 4ECT
Ratios 1st 2.804
2nd 1.531
3rd 1.000
4th 0.705
Reverse 2.393
Differential Ratio
2WD/4WD 3.727*/3.909*
Transfer Case (4WD)
High 1.00
Low 2.566
*4.100 with optional P265/70 R16 tire package (standard on Limited)
For your vehical 2WD:If you know for sure what size wheels were orginally on vehical:
So if you have 15" wheels= 3.73's
So if you have 16" wheels=4.100's
As standard equiptment.
*They might be hard to find,If so... you could put in 4.100 since they are the most common....BUT,I am not sure about the spline/axle diameter of your 2WD,they might be smaller than the 4.100's...Might have to go with 3.73's,or just find a used complete axle assembly.
Ratios 1st 2.804
2nd 1.531
3rd 1.000
4th 0.705
Reverse 2.393
Differential Ratio
Transfer Case (4WD)
High 1.00
Low 2.566
Shaun Crystal Gomban
07-30-2015 10:13 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
