What gains to expect with URD kit + Supra MAF??
Howdie,
I have to full URD setup running with the deckplate out, and am shortly getting an Airraid intake tube. My question(s), what kind of gains would the increased air flow of the Supra MAF get me, and is the FTC that comes with the URD kit able to compensate for the increased flow?
Any first hand experience? Gadget, input?
Thanks!
Thanks!
Originally Posted by yoda-g2
Howdie,
Thanks!
Thanks!
I would save the money on the intake tube, if you want a louder intake just do the "golf ball mod" it has been dynoed and the intake tubes do not give any Hp over a good filter and a deck plate. As for the Supra MAF, yeah what "elnip" said my numbers were about the same and if I remember right up around 2-3psi right before open loop I was up to 11ish on the FTC. I think Gadget even dynoed the results from the MAF and there was some measurable gains, in fact I beleive he still uses one on his rig.
That reminds me I still have that MAF sitting on my shelf from when I sold off everything to get gears and ARB's...
As for "how much" gain you'll get, that's hard to say. Gadget mentions results with a modified VPC on his site:
http://www.gadgetonline.com/Fuel.htm...e%20Converter:
From that chart, it looks like a gain of 26hp. I don't know how this would compare to a straight Supra MAF swap. I can tell you though that in a S/C engine, the stock MAF _is_ a restriction. So anything to get more air through there will help.
Performance wise... Anything that's said about modifying the intake to to produce HP is wrong (as you said). You modify the tube to increase throttle response, and to increase intake noise.
Thanks for the input guys. Here's a couple more for you. Will the TT MAF flow more than my current '99 MAF? I've been doing some research and it seems like most guys talk about puting them on '96-'98 rigs. Also will I be able to modify my current air box to make this work, or will I need an air box off an earlier model?
The short of it is yes you can use the Supra MAF with your stock box but it takes some “creative modifications”. The easy solution is just to replace it with a pre-99 box.
Originally Posted by midiwall
Wanna sell it?
Originally Posted by HUTCHSTACO
mark one day i would love a ride in your truck, i have never been in a s/c yota
We can make it happen dude. But be warned, keep in mind that however you feel about the performance I'm getting, your Taco will run even better - you're 1000lbs lighter than I am!
I owe some time to other folks and have to make good on that (Sorry Glenn!), but I promise that we'll go for a ride before you start dropping the big $$$.
anniesball
07-29-2015 11:46 AM
TransAmBandit
07-28-2015 11:30 PM
