What do you recommend for plug wires?
Old 03-03-2008, 05:17 PM
hkspwrsche's Avatar
I usually like magnecore but, wanted to get advice from the yotatech forums. Is there something that's preferred for it's results?
Thanks
HArold
Old 03-03-2008, 05:21 PM
Elton's Avatar
i went with ngk's from www.sparkplugs.com they work great
olharleyman's Avatar
Thanks
HArold
Bite the bullet and get the stock ones the best I have tryed by far. It gets expensive trying new ones and having to replace them because they dont get you the best conductivity. Plus the factory ones are numbered and have the extra wrapping around them for heat and have the wires setup in holders already for plug and play pain free operation.
just my thoughts
Old 03-03-2008, 05:31 PM
904_runner's Avatar
Yea i have heard go with toyota ones from mechanics that specialize in toyota!
BTW around how much does the wires cost?
Old 03-03-2008, 05:32 PM
crolison's Avatar
I just did my plugs and wires, and i was going to do oem ngk plugs from oreillys and order the plugs and do them later, but once i pulled one plug wire it came out in like 3 pieces.
So i had to get some duralast wires, i will prolly switch over to oem ones soon.
I hate that the old ones just crumbled apart, i had to get a friend to take me to the part store to get some extra thin pliers to get the wires off of the plugs.
Old 03-03-2008, 06:00 PM
hkspwrsche's Avatar
just my thoughts
IS there a good online vendor for factory parts? Ive heard Magnecor and NGK suggested on the searches. Is factory the best out of these options?
Old 03-03-2008, 06:06 PM
crolison's Avatar
Just call northridgetoyota parts department, they give a yotatech discount. Some percentage and free shipping.
Froggy93's Avatar
X2 on the OEM. I have had experience with aftermarkets and they just don't seem to run like they do with oem's. I worked at a dealer for the past 3 1/2 years and nobody would use anything but oem. Plus, they come with all the little plastic clips and holders.
Old 03-03-2008, 06:08 PM
904_runner's Avatar
how much for oem?
Old 03-03-2008, 06:16 PM
Froggy93's Avatar
Somewhere around $50 here is a link I found.
http://www.trademotion.com/partlocat...96&catalogid=1
96-02 wires are listed at $45. If memory serves me correctly, dealer shouldn't be much more.
Old 03-03-2008, 06:28 PM
Nate08's Avatar
I have the OReilly Lifetime ones. I'll probably switch to OEM's soon enough to try to get the best MPG possible. I'm running dual electrode NGK's for plugs.
Old 03-03-2008, 06:30 PM
904_runner's Avatar
Damn, i just check for a 90 4runner, they want $75! Thats insane!
Old 03-03-2008, 11:44 PM
Elton's Avatar
denso's from sparkplugs.com are $27 dollars
Old 03-03-2008, 11:48 PM
Elton's Avatar
also ngk's from there are also $27 dollars for the 3.4L they work great too also denso's are $34 dollars
Old 03-04-2008, 12:40 AM
Ya but I just changed mine for the first time and they lasted 229,xxx so figure that into the price. With others you will have to replace them 2-3 times at $27-$34 a time it works out to be a very good deal
Old 03-04-2008, 02:48 AM
rocket's Avatar
Across ALL import forums, NGK wires are regarded as and highly recommended for OEM replacement.
I've said it before and i'll say it again: blue NGK wires = OEM.
Save some coin.
Old 03-05-2008, 08:52 AM
GSGALLANT's Avatar
Save some coin.
I just installed blue NGK's on my '93 4R monday, and I checked the impedance of the wires before installing them. The three long wires were approx 7 Kohm, an the three short wires and the supply wire to the distributor were all roughly 5 Kohm. They seem like excellent wires... even lower impedance than my stock ones that came off (although the stock ones had 300,000 km on them... the PO said "why change something that still works? ) Well, after the last rain storm we had here and the truck bucking like a wild bronco, I took the old stock wires off and found a large crack in the insulation on one of the wires. With the new NGK wires, it runs better than it ever has since I own it.
Old 03-06-2008, 06:11 AM
dirtoyboy's Avatar
OEM TOYOTA....they are about 70 bucks.....
Old 03-06-2008, 06:25 AM
98runner210's Avatar
I have the blue NGK's, they are numbered and have the extra protectors where needed like the OEM. One drawback they don't come with the clips to hold the wires to the coils. I had to go get those seperately since mine all cracked and broke when trying to get them off.
Old 03-06-2008, 06:40 AM
pfdaxe's Avatar
I have been using the Magnecor blue 8mm wires part # 60216:
http://magnecor.com/magnecor1/main.htm
Quick Reply: What do you recommend for plug wires?
