what is the difference in tires?
what is the difference between the Super Swamper TSL and the SSR Series tires? which is better. what makes them different i dont know and cant tell
The SSR is supposed to have a tighter tread pattern and mostly comes in only smaller/average tire sizes. Also remeber that there are two types of TSL Radial and Non-Radial.
Best off road - TSL Non-Radial
Best on Road - SSR
Best on Road - SSR
There's lotsa differences amongst those you named.
The TSL is The Original swamper tire, old tech, and it's perhaps the noisiest tire ever made. They come in radial and non radial.
The SSR has a stickier rubber compound too. One of the first really good rock crawling tires. Wears fast on the street. Might be less agreesive than the TSL, but still one of most aggressive treads on the market.
The Truxus is a newer and supposedly lower cost tire with a more all around friendly and useful tread pattern. So they say.
There's tons of info online about all these tires. Try using Google.
http://www.4wheeloffroad.com/techarticles/28358/
the SSR are too expensive, im goin to college i got to watch $$$ so what about the TSL v.s. the Truxus/mt
and which is better to get the TSL or TSL radial is there any different besides one is radial like do they both perfom same and sit same etc.
Just look at em - the TSL is WAAAAY more aggressive.
You will find the Truxus lasts a lot longer - its probably your daily driver too right? The TSLs will thumb and vibrate and generally make a lotta noise,and will wear fast. The TRuxus is pretty much a generic modern MT type tread, and radials are Always better than bias plies unless they are dedicated off road tires. Just my opinion - but I did sleep at a Holiday Inn recently. (And I've been through dozens of various tires on 4x4s in the past 20 years...)
Your best bang for the $$$$ is probably the house brand at Walmart unless you are looking for big sizes (big= bigger than 33s) . They have a MT type tire that is really inexpensive. (liberator or desalinator or something or other.)
djpg2000
11-11-2020 04:56 AM
coffey50
07-28-2015 10:55 AM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
