What is this connection?
Old 10-14-2003, 07:19 AM
Blair's Avatar
It sits on top of the rear diff and has a vaccuum line attached.
Old 10-14-2003, 07:20 AM
Blair's Avatar
Sorry, tried to post a pic, but the file was too large.
I'll try later...
Old 10-14-2003, 08:13 AM
Jonathan's Avatar
I'm guessing it's probably your rear differential breather. That's the only thing that I know of that sits on top of the rear differential.
Old 10-14-2003, 09:26 AM
Blair's Avatar
Nope, I know it's not the breather...that's off to the left side.
I'll try another pic here...
Sorry about the crappy pic...best I can do from here
Old 10-14-2003, 09:33 AM
mtnfreak's Avatar
Maybe for a locking device? Where does the other end of the hose go? Anything happen if you pull the hose off?
Old 10-14-2003, 09:46 AM
Glenn's Avatar
The ABS sensor comes off the top of some differentials. I don't know what kind of line the ABS uses, having never seen the actual line before. I just know that there is a hole for the ABS sensor on the top of my V-6 differential that I had to close off.
Old 10-14-2003, 10:02 AM
tck4x4's Avatar
That is the Rear ABS sensor.
I have a '91 4runner, and have removed the rear diff before.
On mine, it was impossible to remove from the third member,
and the plug was impossible to access, so I cut the cord, then spliced the wires back together. So far, no problems with the ABS.
Steven.m.paulk
06-07-2020 10:45 AM
puddlepirate
09-29-2015 08:02 PM
voiddweller
09-28-2015 11:21 PM
JPV
09-28-2015 03:15 PM
Rcbc92
09-26-2015 03:00 PM
Quick Reply: What is this connection?
