What can i do to make my motor run longer??
Old 04-19-2004, 04:52 PM
J95runner's Avatar
hey guys i have a 92 toyota 4x4 pickup 5 spd. with the 4 cyle 22re motor in it. It has 166k miles on the truck and runs great, but this is my main truck so i want to make sure that it will run even longer, I was thinking about taking off the oil pan and cleaning the oil pickup screen, since some people say thaey can get clogged after awhile. I had changed the timing chain arounf 30k miles or so. should I chance the tranny fluid? that has never been changed? what else can i do to make sure it runs for a long time? thanks alot
Jon
Old 04-19-2004, 04:57 PM
radrex's Avatar
If it ain't broke.....
Old 04-19-2004, 06:16 PM
EDGE's Avatar
just change the oil, nothin more but also realize at 166k it will have more things go wrong but it should be able to go over 200k, just pray to the toyota gods
Old 04-21-2004, 10:18 AM
Guest
OtFoFyRoOtAaD91's Avatar
i would replace the crank shaft return spring, it's about 160K when they start to weaken. shouldn't cost much and isnt that hard to get too either.
Old 04-21-2004, 02:05 PM
BruceTS's Avatar
Install a larger fuel tank.....
Old 04-21-2004, 02:06 PM
rimpainter.com's Avatar
I replaced mine the other day. My truck is much faster now.
Old 04-21-2004, 02:33 PM
ayoung101's Avatar
what's a crankshaft return spring?
also, dude, if you changed your timing chain at 30k and now have 166k, i'd do that pretty soon. 136k on a timing chain in an interference engine is a lot. especially when it's suggested to do it every 60k. (unless you meant 30k AGO, in which case you're good)
Old 04-21-2004, 04:51 PM
The Rusty Gear's Avatar
Is there a way of telling if the crankshaft return spring is getting weak?
Old 04-21-2004, 04:57 PM
J95runner's Avatar
sorry, yeah i meant 30k miels ago
Old 04-21-2004, 04:58 PM
Scofco's Avatar
That made my day. Thank you.
Old 04-21-2004, 05:00 PM
J95runner's Avatar
yeah about that crankshaft return spring, is there a way about telling if its bad and how hard it is to change?
Old 04-21-2004, 05:49 PM
I didnt have the time or the $$ to pick up an OEM CRS (Crankshaft Return Spring). So I just went to Home Depot and got one from the garage door section. It actually works better. My rig will smoke a supercharged 4Runner now.
Old 04-21-2004, 05:53 PM
BruceTS's Avatar
After I saw the heading of the post, that was my very first thought, but after reading it, I knew he meant LAST LONGER.......... I just couldn't resist
As for the CRS............ but
Old 04-21-2004, 06:06 PM
Ok ok, jokes over. We are kidding.
Jon -
We are just giving you a hard time. Just change your oil and perform routine maintenance as scheduled in the manual. You should be fine.
Old 04-21-2004, 06:20 PM
BruceTS's Avatar
Jon -
Yea, only in the ever creative minds on this board, will you find some of the most impossible things. No such a beast
Old 04-21-2004, 06:36 PM
J95runner's Avatar
haha i was gunna say, I have never heard of a crankshaft return spring, thanks guys
Old 04-21-2004, 07:31 PM
radrex's Avatar
I'm thinking that a crankshaft return spring that was big enough would be kind of like a poor man's hybrid - with a gas/spring hybrid You drive it straight until you get the spring wound up really good - then turn around - put it in reverse and release the spring.
Old 04-22-2004, 07:08 AM
So, does this mean that I don't need to grease my muffler bearings anymore?
Old 04-22-2004, 07:43 AM
Swede's Avatar
No, you still do but make sure you use CANOLA OIL!!! Very important!!!
Old 04-22-2004, 10:37 AM
Highland Runner's Avatar
Use an oil filter with an anti drain back valve. This will keep the timing chain from flapping around on start up, because the tensioner works on oil pressure.
Team420
01-12-2021 04:57 PM
camdenbuck
07-07-2015 07:33 AM
B. Graves
07-03-2015 04:10 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
Quick Reply: What can i do to make my motor run longer??
