What am i missing???
Old 09-05-2007, 02:19 PM
apalmer1's Avatar
Im currently putting a centerforce clutch into my 04 taco (5VZ-FE, R150F) and for whatever reason i can not get the tranny to slide back.
Things i have removed/unbolted:
-5spd stick, and 4wd stick
-wiring harness
-front driveshaft
-rear driveshaft
-plumbing and slave cylinder
-bellhousing bolts, including the 2 bolts to the starter
-the 4 bolts on the engine side of the tranny, and the clutch cover they hold on.
Im using a small hydraulic table as a tranny jack and i have the transmision about as close to level as it could get, but after pushing and tugging and prying i cant get the damn thing to budge, i even tried letting the back end sag down a bit to loosen the front up.
Somebody who has done this before, what am i forgetting???
Old 09-05-2007, 06:26 PM
Fo-runna's Avatar
Cross member?
Old 09-05-2007, 07:01 PM
Staff
DeathCougar's Avatar
Did you take off the corssmember as Fo-runna said? You should have 4 12mm bolts holding the rubber mount to the cross memer, as well as 4 14mm bolts/nuts holding the cross member on.
Old 09-05-2007, 09:38 PM
pennywize's Avatar
my guess is cross member...
TheBFA
02-15-2020 06:55 AM
Badlander
10-10-2015 08:05 PM
voiddweller
10-02-2015 07:47 AM
hiluxinargentina
09-30-2015 05:51 PM
voiddweller
09-28-2015 11:21 PM
Quick Reply: What am i missing???
