Weird problems with my Tacoma!
Hey ya'll, just recently when I back out of a parking spot and then put my Tacoma in drive, it doesn't move at idle speed right away. It sits still for a few second and I usually have to give it some gas in order for it to go. I'm not sure what the cause of this could be?
Also a few other problems- when I brake from going over 55mph my truck tends to shake a bit, it was a lot worse last summer but I got my tires aligned and it got a lot better. It still does it a good bit though. Should I replace the rotors or even just do the Tundra brake mod? It seems some people have solved that issue by doing that mod?
Thanks, Superswole
Thanks, Superswole
I'm assuming its an auto, if so you should have the transmission serviced. Get the fluid flushed or you can drain and fill it several times till fluid looks nice and healthy.
If the truck shakes while braking i'm gonna say it could be the warped rotors or out of round drums.
icentropy
07-14-2015 10:23 AM
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
07-12-2015 07:15 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Poncho0206
07-10-2015 06:21 PM
FS[NorAtl]: 05+ tacoma leveling lift front MA
akaphilly
07-09-2015 02:18 PM
