Weird Electrical Problem
Old 09-02-2008, 10:10 AM
98runner210's Avatar
I recently put new foglights and wiring. I just wired it up simply from the positive battery terminal with an inline fuse and grounded. The switch isn't tied into the ignition anywhere, I need to remember to do that later so I don't accidentally leave them on and drain the battery. The other day on the highway headed out of town, AInoticed if I have the foglights on, it makes the fuel gauge read about an 1/8th less. IF I turn them off, the gauge goes back up. WTF?
Old 09-02-2008, 11:23 AM
INFINITY's Avatar
good question WFT is right???? voltage drop??
Old 09-02-2008, 11:33 AM
It can't be a voltage drop. I turned on the fogs with the headlights on and nothing dims. The gauge just slowly drops. Maybe I need to try a better ground/different ground.
Old 09-02-2008, 06:55 PM
any ideas?
Old 09-03-2008, 05:20 PM
Ron Helmuth's Avatar
ground or hot- got to be one or the other
you have diagnosed it already yes. I am presuming/assuming your ground for the switch or the lights themselves is sharing that ground with the fuel gauge.
Let us know please... wiring is two wires so if not the hot then it generally is the ground. Easy for me to say, let us see if that is so.
Did you ground your switch under the dash near the fuse kick panel -I am guessing?
Old 09-08-2008, 10:13 PM
Ritzy4Runner's Avatar
Something to consider when you start adding lights and other electrical accessories is to do the Auxillary Fuse panel. GR8 easy mod to do that will save you lots of time and trying to find connections for power. No need to worry about ignition hook up either. As for leaving your lights or other accessory on, you can also do indicator LED like I did on my driving and fog lights. There are two flat mount LED in my dash/gauge cluster to remind me that they are on. Also using the Aux fuse panel will eliminate potential voltage drop across other circuits that you had to tie into before like you are having now. Good luck! If you need any help with any of the recommended mods you can do a search on my installs and get pictures and directions that I used to install mine. Or you can pm me with any other questions
coryc85
09-09-2015 06:24 AM
Yota.Jay
07-23-2015 08:08 PM
v_man
07-23-2015 04:01 PM
icentropy
07-14-2015 10:23 AM
AaronM
07-08-2015 07:15 PM
Quick Reply: Weird Electrical Problem
