Weird cooling issue. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-18-2004, 08:02 AM   #1 (permalink)
Send a message via AIM to 88RunnerV65Spd
Unhappy Weird cooling issue.
I've never seen this before. Started a few months ago. The temp guage would climb alittle and stop. It wouldnt get higher (into the red). Put the heater on and it comes down to normal. Changed coolant/t-stat/cap. Temp doesnt go up anymore BUT.....the part I've never seen before...after shutting down the engine...maybe 45 sec. to a minute, the rad cap would release coolant into the overflow tank. That tells me there's no leaks cuz there's enough pressure to pop the rad cap. It would fill the overflow to where its drippin on to the ground.
Truck starts fine/runs fine. Never been overheated while i've owned it. I'm thinking blockage in the radiator? It's the original radiator w/ 310k miles on it.
Thanks for listening...now back to your regularly scheduled program.
__________________
88 Runner V6 5spd. 310k miles. BFG 32 KO's. Rancho 9000's. Downey torsions/leafs.
Mostly stock compared to whats out there.
88RunnerV65Spd is offline
Old 11-18-2004, 09:05 AM   #2 (permalink)
smiljko's Avatar
Sorry to say It's very possible that you have a headgasket leak or even a cracked head .I had the same problem- it appeared to be cracked head - exhaust gases went to the cooling system and pressurized it-and there are symptoms you described.I tried everythig you did and didn't beleive that the head was the broblem because there was no water in oil or vice versa.Try and open the rad cap when cold and see if you can smell exhaust gases.
smiljko is offline
Old 11-18-2004, 08:39 PM   #3 (permalink)
Yeah, I'm thinking the same thing. I've just never seen it happen this way. There's no milk under the oil cap and it runs just as good as when I got it.
Thanks for confirmation on that.
__________________
Old 11-19-2004, 05:05 PM   #4 (permalink)
Nic
Nic's Avatar
Before I finished reading your post, I was thinking blocked radiator. I had a 77 Corolla that started to overheat. After changing the water pump, I discovered that it was just blockage in the radiator. I had it back-flushed and it helped, but would still get hot if I sat idling for somewhere too long.
__________________
Nic
1997 Tacoma 4X4 Xtra Cab 2.7L 5 speed
Nic is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
weird cooling problem elkdog 86-95 Trucks & 4Runners 6 06-13-2009 10:09 PM
Weird cooling issue w/ 22re boostaddctn 86-95 Trucks & 4Runners 8 09-25-2006 01:01 PM
weird timing issue surfcaster 86-95 Trucks & 4Runners 6 08-30-2006 05:49 PM
Weird Starting issue UKMyers 86-95 Trucks & 4Runners 15 05-20-2006 11:41 AM
What part is this?? Cooling issue. Funk_Runner 95.5-2004 Tacomas & 96-2002 4Runners 13 11-08-2005 11:11 AM
2009 InternetBrands, Inc.
