Weird buzzing noise when turnning signal is on
Old 04-12-2006, 02:51 PM
TFJ-4runner's Avatar
Latley the 4runner has been making a loud buzzing noise when the turning signal is engaged. The light does not come on in the dash to show its on either. Could this be a fuse or mabey a short in a wire? All help is appreciated.
If it Helps
2000 SR5 4runner
2wd
Automatic
Old 04-16-2006, 09:25 PM
hondavxr's Avatar
Your turn signal switch is going bad. The contacts inside the switch is sticking.
Old 04-16-2006, 09:32 PM
AH64ID's Avatar
agreed, the same thing happens in my 92 when the switch sticks betweem indicate and off
Old 04-16-2006, 11:28 PM
photoleif's Avatar
had that happen to my wife's old corolla years ago. it shorted enough that the battery puked on us. go get that replaced so you don't have to cringe every time you hear it. that sound is second only to the dreaded "click of death" with a dead battery or a hosed starter, for me.
Old 04-18-2006, 11:20 AM
FingerMan20's Avatar
ive seen the exact thing in a SHO taurus. you could jiggle the turn signal arm a bit and it would work totally normal. bug the ลลลล out of you, for sure.
Old 04-18-2006, 12:58 PM
Thanks to everyone for all the information. How much would it cost to replace this?
Shoua
13
05-22-2016 05:19 AM
ripp96
07-25-2015 02:32 PM
yourrealdad
07-21-2015 11:13 AM
kvanzandt1
07-18-2015 10:15 AM
icentropy
07-14-2015 10:23 AM
Quick Reply: Weird buzzing noise when turnning signal is on
