The weekend brought a new mod... - Page 2 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-23-2007, 09:58 AM   #26 (permalink)
Sponsoring Member
midiwall's Avatar
Quote:
Originally Posted by Greedy View Post
Yeah -Check this guy's out.
http://www.putfile.com/turborunner
Ummm... raise your hand if you saw this point:
Quote:
Still need a few things like the IPT valve body upgrade and the stall
DOOOOOOOOD! He's pumping all that power through a stock tranny??? WOW!
__________________
~ Mark
'96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams
midiwall is offline
Old 04-23-2007, 03:17 PM   #27 (permalink)
good work man...everything running perfect now?
What MI setup are you using?
__________________
-Johnny
'96 Taco V6 4WD Auto with 262 S2S Cams
New 5VZ-FE & 3VZ-E Cams available
5vz-fe Stock CR FI Pistons NOW available!
www.sea2skytuning.com
Plug and Play EMS!
Perfect Power, Hydra EMS, Arias, Pauter, Manley Performance Dealer....
Weasy2k is offline
Old 04-23-2007, 03:28 PM   #28 (permalink)
Sponsoring Member
midiwall's Avatar
Quote:
Perfect is a relative term in my world. It's definitely a boatload of fun, but there's something screwy with my A/FR. I've been through two O2 sensors in the last month and things aren't normal. The truck feels like it's running rich, but the A/FRs show lean. Fuel trims are UP so it looks like it's a A/FR reporting issue. I'm working on it...
It's a Snow controller with a modified Boost-a-Pump. The controller's AWESOME - it's got a MAP on it and the ability to set for what PSI it starts pumping at and what PSI you want full spray at. I built up a simple LED bargraph circuit to monitor the voltage to the pump so I know when it's armed, starting to spray and full spray. Lotso fun.
Gregg (Greedy) and I are looking to get on a dyno in about three weeks. This should be a BLAST.
__________________
~ Mark
midiwall is offline
Old 04-23-2007, 03:35 PM   #29 (permalink)
Greedy's Avatar
Quote:
I know what you mean...
__________________
- 1999 4Runner Highlander Edition
- Turbonetics BB T3/TO4E TURBO
- URD Fueling
- 3 Inch Turboback Exhaust
- 16x8 Volk TE37X
- OME Lift
Greedy is offline
Old 04-23-2007, 03:49 PM   #30 (permalink)
nice! I cant wait to rebuild my s/c and get back at er
__________________
-Johnny
Plug and Play EMS!
Weasy2k is offline
Old 04-23-2007, 04:10 PM   #31 (permalink)
TFJ-4runner's Avatar
Send a message via AIM to TFJ-4runner Send a message via Yahoo to TFJ-4runner
Do you have any recent pictures of your engine bay?
__________________
"If you refuse to stand behind our troops, then please...by all means feel free to stand in front of them."
1994 Toyota 4runner 4X4-
TFJ-4runner is offline
Old 04-24-2007, 05:47 AM   #32 (permalink)
Sponsoring Member
midiwall's Avatar
Quote:
Who "you"? Me "you"?
I'll get some for ya' this morning...
__________________
~ Mark
midiwall is offline
Old 04-24-2007, 09:27 AM   #33 (permalink)
Sponsoring Member
midiwall's Avatar
pic of under my hood, It ain't pretty, this truck likes the dirt.
(click for a larger one)
The methanol sprayer hose routing is temp. I need to move that tap closer to the TB.
__________________
~ Mark
midiwall is offline
Old 04-24-2007, 03:48 PM   #34 (permalink)
Looks good, at what mileage do you think its to late to install a SC?
__________________
Old 04-24-2007, 03:55 PM   #35 (permalink)
Sponsoring Member
midiwall's Avatar
Just about never.
I think I did mine around 130k, there's 165k on it now but then there was also a complete rebuild about 5k ago.
__________________
~ Mark
midiwall is offline
Old 04-24-2007, 03:58 PM   #36 (permalink)
Just about never.
Really, I guess its not worth it for that much money.
__________________
Old 04-24-2007, 04:12 PM   #37 (permalink)
Greedy's Avatar
Looks like you got a big hole in the top of your hood!!
Can't wait to see what it looks like on the shiny side
__________________
- URD Fueling
- 16x8 Volk TE37X
- OME Lift
Greedy is offline
Old 04-24-2007, 04:12 PM   #38 (permalink)
Sponsoring Member
midiwall's Avatar
??? Ummm... which "that much money"? Are you referring to the cost of a rebuild?
I burned a valve probably by my own fault, it had nothing to do with what would be a normal installation. There are MANY people around here with SC's on... I think I'm the only one here that's burned a valve on the 3.4L.
__________________
~ Mark
midiwall is offline
Old 04-24-2007, 04:15 PM   #39 (permalink)
Sponsoring Member
midiwall's Avatar
Gregg, you gotta stop workin' so much!
http://www.yotatech.com/showthread.php?t=111557
__________________
~ Mark
midiwall is offline
Old 04-24-2007, 04:16 PM   #40 (permalink)
The rebuild, I guess I should of been more clear. When you said never and that you had a 5k rebuild build I assumed the SC had a role in the problem due to high mileage. So I'm assuming 223,000 miles is to much.
__________________
Old 04-24-2007, 04:23 PM   #41 (permalink)
Sponsoring Member
midiwall's Avatar
Ahh... okay.
There's been a TON of talk here over the years about adding a SC or Turbo to the 3.4L. The block can certainly handle the horsepower, but you HAVE to do mods to the fuel system to be able to keep the engine fed. If you don't, then more times than not you run into the engine running very lean on the top end, and pinging hard under acceleration.
I've been a HUGE advocate of the mods and spend most of my time here talking about them. My engine DID have mods on it... When we tore the engine down I had clearly burned a valve, but it wasn't from running lean or knocking. The best guess at the moment is that it;s possible that I was running too _rich_ and was able to ignite all of the mixture.
Anyway... proper fuel mods are a MUST, but then year... 223k could be on the high side of this being a "practical" investment for you.
__________________
~ Mark
midiwall is offline
Old 04-24-2007, 04:25 PM   #42 (permalink)
223? Try 260 at the moment....and i beat the crap out of my tacoma..it went through lots of pinging as i tested different setups...
If the engine fires up and runs good...sc is fine with fuel mods
__________________
-Johnny
Plug and Play EMS!
Weasy2k is offline
Old 04-24-2007, 04:34 PM   #43 (permalink)
ok so one says yes and the other says no. I know that the fuel setup will have to be improved to keep up with the SC, but if I get all the necessary testing done to see if the engine is up for the SC will it be safe to do it. I plan on doing this a good while down the road but I wont even bother if its a waist of time.
__________________
Old 04-24-2007, 04:48 PM   #44 (permalink)
Sponsoring Member
midiwall's Avatar
I vote for Johnny's answer!
Get a compression test done, and a leakdown. Those will probably be the two big things that will help you judge what you're in for.
Has the engine been well-maintained? (water pump, timing belt, filters, plugs, injectors pulled and cleaned?) Are you the original owner?
One HUGE thing that I can say here is that my block/crank/cams/connecting rods/most pistons were _like new_. I DID score a couple of pistons, but that's from driving with that burned valve for about 4k. My engine temps were WAY high, to the point of destroying the porcelain off of two cylinders (the burned one and the adjacent).
__________________
~ Mark
midiwall is offline
Old 04-24-2007, 05:06 PM   #45 (permalink)
^ YOur pistons were really pitted good ol detonation...
thanks again for giving them to me to send away!
__________________
-Johnny
Plug and Play EMS!
Weasy2k is offline
Old 04-24-2007, 05:24 PM   #46 (permalink)
AH64ID's Avatar
Send a message via MSN to AH64ID
sweet mark... cant wait for the dyno results..
__________________
-John
'05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600
2003 SR5 4Runner, V6 4WD. 1" cornfed lift
Previous Toyota's '92 Red Truck NALA
Speed doesn't kill, its the sudden stop that hurts.
AH64ID is offline
Old 04-24-2007, 05:24 PM   #47 (permalink)
No I'm not the original owner. The engine is in good shape and there is no problems reported on carfax. I will be picking it up within the next few weeks. I believe both the water pump and timing belt have roughly 20k miles of use. So the compression test and a leakdown are my best bet of determining if the engine is up to it correct? I figured I would ask now that way I would know if it was even worth considering.
__________________
Old 04-24-2007, 05:39 PM   #48 (permalink)
Sponsoring Member
midiwall's Avatar
Ahh... so this will be a newly acquired vehicle... what year is it? 2WD, 4WD? 4Runner, Tacoma, T100? Auto, Manual? Where did the truck live before?
I think it's th place to start... if the cylinders can't hold compression now then they're gonna have issues with 7psi of air forced into them.
If you can borrow a borescope it may not be a bad idea to get a look inside the cylinders.
You'll also wanna drain all fluids and check for things like metal filings in the oil and tranny fluid, good color in the antifreeze, test the antifreeze with chem test strips first: http://www.google.com/search?&q=testing+antifreeze - that can give you a good idea as to how much someone paid attention to the rig; pull the intake tube and check for deposits at the TB - again, a good indicator of someone caring or not... Replace the PCV valve, air filter, oil filter. Drive it for a thousand miles or so and note the gas mileage. That's a good indicator of engine heath as well.
__________________
~ Mark
midiwall is offline
Old 04-24-2007, 08:12 PM   #49 (permalink)
Texas_Ace's Avatar
Send a message via MSN to Texas_Ace Send a message via Yahoo to Texas_Ace
I am also planning on supercharging my 2000 4runner. The end result i hope to be simular to marks in mods. Now externally it will be a little differnt.
It has 120K on it right now and it is in the shop getting the timing done right now. i will then be doing every little tune up thing there is to do and then i will drive it for a few weeks to break it in before getting into modding it.
I will start off with the small stuff so that when i get the 2.5K for the actuall super charger it is ready to bolt on and every thing else is done.
Texas_Ace is offline
Old 04-24-2007, 11:12 PM   #50 (permalink)
hiloracerboy84's Avatar
how effective was the port/polish job on its own? how much does it cost to do something like that?
hiloracerboy84 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
weekend of wheelin and mod-buyin! lee 95.5-2004 Tacomas & 96-2002 4Runners 32 02-04-2006 05:19 AM
Had a mod-full weekend... Marc P Offroad Tech 3 12-17-2005 04:54 PM
Did the Stereo Mod this weekend . . . DrummerDaveB 95.5-2004 Tacomas & 96-2002 4Runners 3 06-23-2003 08:45 AM
A mod-ful weekend...just little stuff :) Bob_98SR5 95.5-2004 Tacomas & 96-2002 4Runners 2 11-10-2002 01:23 PM
2009 InternetBrands, Inc.
