Water leaking on driver's foot
While driving a long time with the defrost on, I notice cold water pouring on my right foot. I cleared out the blockage for the AC, elbow that is on the passenger side in engine bay. Is there another drain?
Not familiar with your model but there is usually only one. Is it draining water after you cleared it? If not it's probably still clogged. Definitely water, not coolant?
Not coolant. And not rain water. It happened when using my AC. I cleared the plug. Still happening, only on drivers side. Theres a black vent in the center console facing the pedals. The water comes out of that.
Junior Member
The elbow pulls right out and is most likely where your clog is. I usually get a spider or insect of some kind making a nest in there. I have to clear mine yearly.
Just pull the elbow out, clean it and stick it back in.
No need to pull the grommet.
09-04-2015 09:27 AM
Avenged
07-09-2015 07:55 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
