water, how deep ?? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-09-2003, 05:27 PM   #1 (permalink)
water, how deep ??
can I go with the stock suspension?
Mainly talking about how to negotiate gigantic NYC waterholes..
Cheers
__________________
'03 4Runner Sport V8 4x4
LC Lite is offline
Old 06-09-2003, 09:02 PM   #2 (permalink)
tomus1000's Avatar
There are gigantic waterholes in NYC?
__________________
-Noel-
2002 Tacoma Double Cab Impulse Red w/ color keyed package...2nd generation supercharger...TRD off road package...TRD boost guage...TRD tranny cooler...Borla exhaust...Speed Liner spray in bed liner
tomus1000 is offline
Old 06-09-2003, 09:11 PM   #3 (permalink)
Send a message via AIM to vmaxjohn Send a message via Yahoo to vmaxjohn
just about...
up to the axles is a good limit. At this point, water will try to find ways into axles, brakes, etc. If you have any seals that leak fluid, water will be entering there first.
How deep are you talking? If you've got long but not too deep of a hole, go as slow as you can to avoid drowning anything. Good luck!
__________________
If guns kill people, then my guitar can teach without me!
vmaxjohn is offline
Old 06-10-2003, 07:53 AM   #4 (permalink)
GV27's Avatar
You can go a bit higher than the axles. The proper technique is to go just fast enough to create a bow wave in front of the truck to minimize the amount of water that goes into the engine compartment and most importantly the intake. Go to fast and the water will crash over and go into the intake. If the water is shallow enough there is no too slow but at the limit you can go slightly deeper if you can go a bit faster and set up a wave.
Of course be careful you know exactly how deep the water is. Get out and wade if you're not sure if there might be a big hole that'll suck the truck down! Use a stick to probe for depth (so you don't go into the hole either!!).
C
GV27 is offline
Old 06-10-2003, 08:50 AM   #5 (permalink)
Good Times's Avatar
Send a message via AIM to Good Times
If you plan to do alot of swimming with your 4runner, I recommend doing the rear breather diff mod It's easy to do and it'll move the rear diff breather up to a higher location thus giving you the ability to swim deeper.
Then the limitation will be the lowest point for all breathers and your intake (which ever one is lower).
I think this should do it right? (someone chime in please!)
Good Times is offline
Old 06-10-2003, 09:47 AM   #6 (permalink)
What about auto tranny vents? I know GM has an atmospheric vent on the housing, usually on top somewhere. Not sure on the Yota's, this is my first auto, and I haven't even crawled under there to check it out yet!
Really, this is the only thing a Jeep has an advantage on. Jeep runs lines all the way up to the engine compartment with little caps at the ends. Too bad they suck water into the intakes with reckless abandon!
__________________
vmaxjohn is offline
Old 06-10-2003, 10:10 AM   #7 (permalink)
Bumpin' Yota's Avatar
Send a message via AIM to Bumpin' Yota
I had to clean out my pants after this run, but I'd try and avoid water like that if possible....
__________________
3vze, 4x4, sr5, 90, auto, LSD
2x dB Drag World Finalist
2003 Nopi Nat. Street B champ
2004 SBN Street C champ
2004 SBN Advncd NW Champ
2004 Former WR Holder in NW.
SPL: 159.8db @ 42hz
In loving memory of Jamie Riggs 5/15/85 - 10/8/04
Bumpin' Yota is offline
Old 06-10-2003, 10:20 AM   #8 (permalink)
GV27's Avatar
^^^^^^ Perfect illustration of the bow wave.
If you do the snorkel mod where you run the intake back to the rear of the Engine compartment you can go deeper than that. My momma used to have an Isuzu Amigo that I wheeled the crap out of. It had the intake in the rear of the compartment and I went through stuff w/ the water washing onto the front of the hood w/ no problems!
Pulled out all sorts of drowned Jeeps w/ it to! LOL.
GV27 is offline
Old 06-10-2003, 10:47 AM   #9 (permalink)
rimpainter.com's Avatar
Quote:
Dude, are you crazy? All that power and stereo equipment, if you went any deeper you would kill every living thing in a 100 yard radius!
rimpainter.com is offline
Old 06-10-2003, 11:02 AM   #10 (permalink)
I've been in water (while wheelin') that was deep enough to need the use of my windshield wipers.
One hole that I went through a few years back was deep enough that the whole hood was submerged and the water was splashing about 2 inches up on my windshield. Talk about your pucker factor. You could hear all kinds of gurgling noises under my hood, as well as the gurgling of the exhaust out back.. Needless to say, I won't be trying that again..
I wish that i had a picture of that murky water hole.. It would look like the pic that Bumpin' Yota posted, only my hood was under water for a distance of 10 feet of so.. Also, I didn't bonzai into this hole or push a giant wave of water either. I just eased into it and crept through it at a steady pace...
Obtw, my truck is stock with no lift, no Safari snorkel and only P265 tires (roughly 31.5 inches tall)..
*edit* I went out and measured the distance from the ground to the base of my windshield. I came up with approx. 49 inches, as well as the height of the front of my hood (off level ground) and came up with over 41 inches.. So, as a guess I'd say that the water hole that I drove through had to be at least 3 and a half feet deep...
Schuey2002 is offline
Old 06-10-2003, 11:57 AM   #11 (permalink)
You may want to measure your tires while you are at it. I would be ecstatic if I had 31.5" from my 265's.
(I am comparing my measurements to yours)
What is the exact height mathematically? Anyone have that tire size formula for 265/16's?
Old 06-10-2003, 12:04 PM   #12 (permalink)
joshik's Avatar
Send a message via AIM to joshik Send a message via Yahoo to joshik
heres a stock yota p/u. probably want to avoid that deep of water .
here i come to save the day!
here's jeff taking some somewhat deep mud
__________________
2003 4Runner Limited 4wd V8. Bone stock except for the Nitto All Terrains.
My Rig
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights.
My Rig
joshik is offline
Old 06-10-2003, 02:34 PM   #13 (permalink)
Your right. It's more like 30 inches for my P265x75x15's..
I was using this gear calculator.... http://www.4lo.com
Even then it lists my tires at 30.6 inches, which is still taller than I just checked using my Stanley,which reads just a hair under 30 inches in height for my tires..
Old 06-10-2003, 03:31 PM   #14 (permalink)
Thanks for all your comments.....
I am going to check my 2003 manual, maybe the exact answer is there..
In the mean time the message I am getting here is that as a rule of thumb the truck should not be driven into water higher than the top of the rims... is this fair ??
Cheers..
__________________
LC Lite is offline
Old 06-10-2003, 03:57 PM   #15 (permalink)
Re: Thanks for all your comments.....
Cheers..
I concur...if you have a rear diff breather.
Old 06-10-2003, 04:23 PM   #16 (permalink)
Robinhood150's Avatar
Send a message via AIM to Robinhood150
Quote:
I don't know about that...here's some pics of a guy in my club that had mud sucked right into his auto tranny. You can see his mud caked tranny filter in one of the shots. http://community.webshots.com/album/61297428fQqzyt
__________________
Steve. '93 4Runner V6 Auto 4x4
Robinhood's Lair. || Gettin' Off 4wd Club member
Lots for sale:5.29 ARB IFS third member... Click
Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in:
a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat...
Lesson...Stay on the TRAIL!
Robinhood150 is offline
Old 06-10-2003, 04:30 PM   #17 (permalink)
jjdeneen's Avatar
nice pic of my truck josh, looks similar to my avitar, i still have mud on my rig from that trip
jjdeneen is offline
Old 06-10-2003, 04:57 PM   #18 (permalink)
AgRunner06's Avatar
Send a message via AIM to AgRunner06
Post
Quote:
Was his tranny toast after that?
__________________
"I'm your huckleberry." - Doc Holiday
- '93 4runner - Sold!
Current Ride - 2001 Chevrolet Silverado 1500 ext.cab, pewter, 5.3L, 3.42s, fully loaded, 68K miles.
FREE ROCKET!!!!
AgRunner06 is offline
Old 06-10-2003, 04:58 PM   #19 (permalink)
Quote:
No, amazingly enough it still runs. He had the dealer flush it out, but it does have problems now and then. I'm sure it won't last too much longer though.
__________________
Old 06-10-2003, 05:52 PM   #20 (permalink)
joshik's Avatar
ITS A JEEP!:pat:
__________________
My Rig
My Rig
joshik is offline
Old 06-10-2003, 09:30 PM   #21 (permalink)
PoBoy's Avatar
Water is the devil. Avoid it if you can until you get a snorkel. There isnt much worse than doing something stupid like plowing through some muddy water to show off to your buddies...and then breaking a couple rods causing thousands of dollars of damage. And all you have to show for it is this hunk of junk sitting in your basement:
__________________
So I sold my '96 4Runner to get married...I was sad. BUT NOT ANY MORE!
Check out my 1985 4Runner with 32,xxx miles!
PoBoyTech.Net
PoBoy is offline
Old 06-10-2003, 09:56 PM   #22 (permalink)
Ok...so did your Yota make it through that Jeep hole, right before your buddy tried it?
I've seen auto trannies take a lot of punishment, but dirt on the inside usually plugs up the tiniest passages and brings the curtain to a close.
That's maybe the only thing I worry about with our 4runner being an auto. Maybe it's time to extend that vent, eh?
__________________
vmaxjohn is offline
Old 06-10-2003, 10:43 PM   #23 (permalink)
I didn't even try the mud hole. I knew I couldn't make it because I'm pretty low and I have AT tires. We had to really goad the guy to go in the mud pit!
I recently extended my transfer case, but I can't really find anything for the tranny. Course, I didn't look too hard though.
__________________
Old 06-10-2003, 10:58 PM   #24 (permalink)
turboale's Avatar
Send a message via AIM to turboale
This is too deep...
Moved the timing belt over two teeth on the bottom sproket (but lucky for me it didn't change the cam timing ) Punctured my radiator, alternator needs to be rebuilt, interior smells like dirt. Electric seat needed to be gutted and cleaned and the alarm was toast. Never again...
__________________
--Austin
RHaus NYC
06 M45 Sport - Beauty
96 4Runner - The Beast
turboale is offline
Old 06-11-2003, 12:35 AM   #25 (permalink)
Turboale,
Yeah, I'd say that is way too deep!
It looks like the mud dragged your truck to a complete stop and then the water had a chance to do its thing..
The hole that I drove through was more of a "water hole" with mud in it.. The "hole" in that picture of yours looks more like a thick, muddy mess; the kind of mud hole that requires large tires and a ton of horsepower..
Hope everything turns out alright.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Deep Water..... keithguts 86-95 Trucks & 4Runners 8 07-18-2007 01:20 PM
water too deep 94 sr5 86-95 Trucks & 4Runners 7 03-13-2006 05:29 PM
Running deep water and mud..? Tacoma750 Offroad Tech 8 03-08-2005 08:50 PM
deep water help forty4 Offroad Tech 11 11-16-2004 06:45 PM
deep water Mikronized 95.5-2004 Tacomas & 96-2002 4Runners 22 01-09-2004 02:00 PM
2009 InternetBrands, Inc.
