Water in dash
Old 10-20-2008, 07:59 PM
firebane's Avatar
Water in dash
Lately when I am under hard acceleration I can hear what sounds like water somewhere in the dash or that area.
If I just cruise around I'll never hear it.
Could there be something else causing this? I really don't want to start ripping the whole dash apart for something so vague.
Old 10-20-2008, 08:01 PM
jason191918's Avatar
Pretty sure you are hearing the coolant in the heater core. Does the noise have anything to do with the position of the temp slider?
Old 10-20-2008, 08:23 PM
firebane's Avatar
You serious? ... I thought about that. But no I haven't tried with the temp slider.. are you saying if its on cold I won't hear it?
Old 10-20-2008, 08:35 PM
SoCalPaul's Avatar
Does it sound like water sloshing in a chamber? Or like water running or draining through pipes?
You shouldn't be hearing water in the heater core unless you have air in the system.
Where do you live? does it rain a lot? Do you wash it often?
Maybe water is caught in the vent/cowling area between the hood & windshield. There are drains there that could be clogged.
Maybe a water bottle under the seat?
Good luck,
Paul
Old 10-20-2008, 08:54 PM
firebane's Avatar
More like something small inside a box rolling backwards for a very short period.
Yah doing some reading and rattling from this area would be something loose externally.
It does have a tendency to rain a bit where I am and no I don't wash it that often
Hmm will have to find these.
heh nope! Its in the dash area somewhere
Good luck,
Paul
answers in bold.
Old 10-22-2008, 11:03 AM
natedfree's Avatar
i had the same problem looked every where for the water but couldnt find it, i checked my coolant and it was really low i had a small leak in one of the hoses, it sounded like water running through a pipe when i took of from a stop. topped up colant and fixed problem
Old 10-22-2008, 12:32 PM
Belize Off Road Team's Avatar
I too have that sound sometimes, only when i turn, it sounds like it is running to one side of the vehicle. And its not low coolant or anything, i dont know what it is.
Old 10-22-2008, 05:36 PM
mjwalfredo's Avatar
I had that sloshing sound when my water pump started leaking. I think you might have air in the coolant.
Old 11-01-2008, 12:01 PM
firebane's Avatar
Ok so.. I discovered this will do it even when I'm sitting still...
And I am losing coolant.. I'm not sure how much to be exact but it does go down. So I either have a leak somewhere .. or something worse.
No white smoke out the tail pipe = good sign.
But haven't pulled the plugs or checked the oil yet.
PETDOC
08-18-2015 05:29 AM
ViperTT
08-14-2015 05:27 AM
TJWilly
07-31-2015 02:05 PM
HookahRoo
07-20-2015 07:06 PM
jjrbus
07-19-2015 02:06 PM
Quick Reply: Water in dash
