Warm Starting Issue
Old 03-30-2015, 08:45 AM
Cactushead's Avatar
Warm Starting Issue w/Video
This has been going on for about 2 years now. Always starts fine when cold but say I come home and come back out in an hour to restart. Turns over, catches but not fully and then shuts off. usually starts fine on the second attempt until the other day when it cranked for a while. Didn't think it was going to start. Battery, plugs, maint. is all up to date. BTW this only happens 3-4 times per month.
2001, 6cyl, AT, 4WD, 112K miles.
Old 03-30-2015, 12:16 PM
aowRS's Avatar
Andreas
Old 03-31-2015, 06:38 AM
aowRS's Avatar
I'm sure your truck is still on the original fuel filter. Pretty cheap to install a new one and see if things change.
Andreas
Old 03-31-2015, 08:42 AM
Cactushead's Avatar
Andreas
Actually forgot about that. Will get one ordered. Any other thoughts?
Old 12-04-2015, 01:50 PM
Cactushead's Avatar
Update. 119K miles and the issue is still around but now it is getting worse. Sometimes it cranks for a while and struggles to catch. New plugs, air filter, fuel filter, battery in last two weeks. Always top tier gas and Techron fuel injection cleaner.
Old 12-04-2015, 01:54 PM
aowRS's Avatar
Crank position sensor or temp sensor or something else.
Andreas
Old 12-04-2015, 02:35 PM
Cactushead's Avatar
Ok where are these located?
Old 12-18-2015, 10:54 AM
Cactushead's Avatar
In case anyone is even looking at this thread (besides aowRS) the problem was a dirty throttle body. $58 and the idle is perfect. Time will tell if that was the starting issue.
Old 12-19-2015, 08:20 AM
Malcolm99's Avatar
All three of my 5VZ-fe's with KM's ranging from 450,000km's to 140,000km's take a few more cranks than your giving yours to catch properly as well as many that I have worked on, I've cleaned TB's and MAS, new plugs, wires, coils, timing check, T-belt replacement and they all do the same thing, this never bothered me as it always started after 4-6 revolutions, so I chalked it up as the nature of the beast, I have gotten the odd 2 revolution start that shocked & appalled me though so I wouldn't worry about it your chasing a ghost.
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
Jnkml
07-06-2015 01:20 PM
slider417
06-22-2015 10:18 AM
jmc88runner
06-18-2015 03:39 PM
Quick Reply: Warm Starting Issue
