Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
VSC TRAC Warning Light
#2 (permalink) |
Personal
Sales Rating: (0)
Believe me, I'm definitely one that believes in 'fixing it yourself', but this is one scenario I'd don't know that I'd mess with. If the VSC/TRAC OFF dash indicators are both on, I believe you may have a problem with the ABS (brake) actuator system. Trust me, the wiring schematic for an ABS system with VSC & A-Trac is a bit extensive.
The first thing I'd do is check the brake fluid levels in your master cylinder. If its low, top it off to the recommend level. Can't say for sure, but you may cause further damage if you continue to drive it for an extended period. Plus you may be running the risk of braking problems since both of those features (VSC/A-Trac) are all tied into the ABS system. My nickles worth...
__________________
-Scott '01 Black SR5 4x4 w/ Black Pearl's: Detroit Truetrac | Tundra/OME 890s w/ Tokico Trekmasters | SS Diff Drop/Panhard | Tundra rotors/calipers | Rear Diff Breather Extension | Hayden cooler | K&N | ISR | Deckplate | Jet Black PC'd LC 16x8's w/ LT265/75R16 Cooper S/T's "He who wants to protect everything, protects nothing." -Lt. Gen. Adolf Galland, Luftwaffe "There is no instance of a country having benefited from prolonged warfare." -Sun Tzu, The Art of War Last edited by hillbilly; 02-12-2004 at 07:02 AM. |
#3 (permalink) | |
Personal
Sales Rating: (0)
5 years later and this was the only result in the search
![]() VSC/TRAC (ABS fault) from leaking rear axle seal = oil on sensor
__________________
sarcasm noted...and appreciated im with the banned Quote:
#4 (permalink) |
Personal
Sales Rating: (1)
when vsc/trac and engine malfunction lights are on, it means the fuel/air ratio sensor is bad. its the front sensor on the exhaust pipe. already had that problem on my 02 runner. went and had it scanned and thats what it came up with. so i replaced the part and wa'la it was good as new.
__________________
02 4runner Sport 4.88 LOCKED 3" OME lift + 1" 4crawler BL, Tundra Brake Upgrade, LED Gauge cluster and temp control, 285/75R16 Goodyear Wrangler MTR, H/O ARB compressor, FX45 Projectors My Profile |
#5 (permalink) |
Personal
Sales Rating: (0)
Once the MIL(check engine) comes on,it will also turn on VSC TRAC warning light...This does not mean there is something wrong with the VSC/trac,it just that the ECM disables them when it goes into base programing because of the check engine light.....Need to have codes pulled,drivetrain ones in particular.
Also if you have an autozone near you,they will usually pull the codes for free for you......Write them down...p0301,ect,current and history codes..........and be nice,cause they usually think they are super diagnostic tech. Last edited by 97ltd4x4; 01-21-2009 at 07:51 PM. |
#6 (permalink) |
Personal
Sales Rating: (0)
x2... get the codes read and post up the results. Other than that, all you'll get for responses are guesses.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires. 2007 FJ Cruiser - stock |
#7 (permalink) | |
Personal
Sales Rating: (0)
Quote:
![]() Same thing happened to me all the time on on-ramps, even when I took 45 MPH ramps at 20. VSC is just a silly system
__________________
2002 Limited 4wd On the outside: 3.5" full OME, 33" Terra Grapplers, ARB Taco, TRD cat back, full interior/exterior LED conversion, colormatched, LED tails On the inside: Nuvi 625WT|Infinity|Kicker 08ZX750.1|08CVR12|Jensen VM9412/iLink|Dynamat|TRD Emblems Awaiting Installation: OME 883's, LC 8 wraps, Savage Sliders, LC80 wheels, LF 170's |
#8 (permalink) |
Personal
Sales Rating: (0)
Do the Andymod traction control defeat switch and call it a day.
__________________
2002 4Runner SR5
Front: OME 882/OME N91SC, Diff Drop. Rear: LC coils/Rancho RS5000 285/75 R16 Fierce Attitude M/T's With Pacer 164P Wheels/EBC Brakes Magnaflow Exhaust, S&B Intake, And Lots More Profile: http://www.cardomain.com/ride/2915959 |
#9 (permalink) | |
Personal
Sales Rating: (0)
Quote:
![]() my concern is that there may be a band component in my system that i should replace before the recal. did everyones elses problem develop over time? mine did. it when from perfectly fine to beeping when doing 20 on a 45mph off ramp to beeping and shutting off when i am going straight down the road.
__________________
My Build Thread |
#10 (permalink) | |
Personal
Sales Rating: (0)
Quote:
__________________
2002 T4R 4WD Onyx Black Sport with leather. |
#11 (permalink) |
Personal
Sales Rating: (0)
What is a "would"?
Are you just making random posts on Yotatech to promote your website? Hmm. Andreas
__________________
2001 SR5 4Runner 4WD, Dorado Gold, 276,XXX miles 2007 Volvo XC 90 AWD V6, Silver 1995 Porsche 993, Polar Silver peapod-designs.com 231mm Tundra brake upgrade ● Hella 4000 lamp install - in grille . |
| Tags |
| 2002, 2003, 4runner, control, indicator, lamp, lift, light, lights, malfunction, toyota, trac, traction, vsc, warning |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| VCS off, VSC Trac, Check Engine and now 4WD light on??? | kato | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 06-15-2007 04:49 AM |
| Disabling VSC & TRAC - 2001-2002 4Runner with VSC & TRAC Systems | Writeups@YotaTech | Electrical | 0 | 01-11-2007 08:29 AM |
| VSC off, VSC Trac and CEL came on after putting in K & N Air Intake | HenrySacto | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 12-30-2005 01:16 PM |
| 04 4-runner Transmisssion VSC Trac VSC off lights | freemanc | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 03-10-2005 09:57 AM |
| VSC/A-TRAC Warning Lights | broknlgs24 | 95.5-2004 Tacomas & 96-2002 4Runners | 47 | 10-06-2004 10:35 AM |
