VSC TRAC, TRAC OFF, CHECK ENGINE lights - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-23-2007, 07:34 PM   #1 (permalink)
Having problems with acceleration from stop and on highway with my 2001 4 runner. The truck would hesitate and stumble slightly as I accelerated. Changed air filter, fuel filter, and put injection cleaner in tank. On the highway as I accelerated to pass a car had a lack of power and check engine , VSC TRAC, and TRAC OFF lights all came on. Truck still had no power, hesitated, and stumbled during acceleration. I was dropping it off to get some paint done so I did not pull the code. It has 84,000 mi and trans. Fluid is full. Any ideas will be appreciated thank you.
nathan gailey is offline
Old 05-24-2007, 08:01 AM   #2 (permalink)
eric-the-red's Avatar
Almost impossible to tell without pulling the codes. Could be bad plug, coil, injector or a bunch of other things.
eric-the-red is offline
Old 05-24-2007, 07:20 PM   #3 (permalink)
Kerby J's Avatar
Send a message via AIM to Kerby J
i kinda had the same problem and mint turned out to be a bad oxygen sensor and it happened round 78000 miles so that could be the problem
Kerby J is offline
Old 05-30-2007, 12:47 AM   #4 (permalink)
Allen's Avatar
try to check your fuel injector, ignition coil or it could be that your toyota oxygen sensor gone bad and it needs a replacement. try also looking for some loose connections or cross wired.. good luck..
Allen is offline
Old 06-26-2007, 11:58 AM   #5 (permalink)
WolfT's Avatar
Engine Lights
You've probably already fixed this by now but I've had the same lights come on twice. First time was a evap canister and the 2nd was a Fuel/Air Ratio sensor, basically a fancy O2 sensor but required for California spec emmissions. It also cost twice as much of course. Install is a snap for the sensor, the canister I had the dealer do it.
__________________
A full tank and some good music
WolfT is offline
Old 06-29-2007, 06:34 AM   #6 (permalink)
Where did you get directions to replace the air/fuel sensor. I have a bad one and the dealership wants $350 to replace it.
kato is offline
Old 03-25-2008, 01:03 PM   #7 (permalink)
kbrizing's Avatar
Engine, VSC Trac, Trac Off warning lights
Bought my 2002 4Runner (2WD) a year ago this week and have had no problems at all, what a cool truck!
A couple of days ago was driving up the freeway and engine, VSC trac & Trac Off warning lights all lit up at same time. After calling the dealer and researching forums, I'm pretty sure it's an oxygen sensor or mass air flow (MAF) sensor.
Dealer wants $135 just to diagnose as do other reputable repair shops.
Any way to figure this out without that cash outlay?
I see the responses in this thread and were helpful, but I'm still stuck without knowing for sure what code it is. Don't wanna have to spend more than really necessary, so I'm asking (again).
The soonest anybody can get me in to diagnose is Friday and I'm 2 days into a week of vacation already that I've been planning for 3 months and had some camping/fishing scheduled. To top it all off, today happens to be my birthday (woo hoo!) and I'm stuck without reliable transport.
Do I need to park this machine till diagnosed and repaired or what?
Longing for the woods,
KB
Oakland, CA
__________________
KB
kbrizing is offline
Old 04-09-2008, 08:08 PM   #8 (permalink)
kbrizing's Avatar
Cel, Fuel/air Or O2 Sensor
Quote:
No, haven't gotten it repaired yet. Broke out the mountain bike and using the subway till I do. How much did the evap canister run you? I was thinking it might be fuel/air but assumed was same as 02 sensor. I believe there are 3 sensors, 1 before the cat and 2 after, may be wrong. Dealer wants about $125.
I found the part online for less than $60, but you gotta get the right one, may be more:
http://www.rockauto.com/catalog/raframecatalog.php?
carcode=1388707&parttype=5132&a=FRc1388707k501671
Called the dealer again today to see if they would ck the code when I take it in next week for a recall repair (lower ball joint) that Toyota sent me a letter about (dealer pays). They said no and want $135 just to diagnose.
Checked w/AutoZone and Pep Boys to see if they would do for free and they said no, too. They have the scanners for rent (about $165, refunded), so I think I may go that route. Just don't wanna be wrong or could get more expensive. I'm think I'm looking at between $300-400 w/labor.
I got a lot of good information online. Here's a good one, I thought:
http://www.4x4wire.com/toyota/4Runner/tech/O2_Sensor/
and this one has some possible codes and links:
http://www.toyotanation.com/forum/sh...ad.php?t=39767
Lemme know if you find a solution.
__________________
KB
kbrizing is offline
Tags
41, 43, 44, 47, 4runner, 88, abs, check, delta, engine, light, off, toyota, trac, traction, vsc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
VCS off, VSC Trac, Check Engine and now 4WD light on??? kato 95.5-2004 Tacomas & 96-2002 4Runners 1 06-15-2007 05:49 AM
TRAC OFF, VSC TRAC, ABS lights on mini_fly 95.5-2004 Tacomas & 96-2002 4Runners 15 05-12-2006 05:58 PM
01 SR5 T4R ck engine and vsc off/trac lights - resolved/warranty Delta Sierra 95.5-2004 Tacomas & 96-2002 4Runners 0 03-07-2006 01:41 PM
VSC TRAC/OFF and check engine :( voltageGSR 95.5-2004 Tacomas & 96-2002 4Runners 3 03-08-2005 05:06 AM
03 check engine/vsc/trac problem.... help! Good Times 95.5-2004 Tacomas & 96-2002 4Runners 5 03-25-2003 09:23 AM
2009 InternetBrands, Inc.
