VSC off, VSC Trac and CEL came on after putting in K & N Air Intake - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-28-2005, 03:33 PM   #1 (permalink)
Hi there,
I recently replaced the factory Air Intate system with K&N Air Intake (FIPK 57-9015-1) for my 2001 4Runner. Two days later VSC off, VSC Trac and Engine Light came on. I'm not sure if these lights came on because of the new air intake or it is an unrelated issue. I called K&N and they suggested that I unplug the negative battery for at least one full hour and see if the light will be gone. I did as suggested and so far so good the lights are gone...I'm hoping that they are not coming back. Have any of you put K&N Air Intake in your 4runner? Did I do something wrong? Do you have any suggestion as to what may have gone wrong? I'm worried that there might be a bigger problem in the future.
Thanks for your help!!
Henry
HenrySacto is offline
Old 12-28-2005, 04:11 PM   #2 (permalink)
Send a message via AIM to 2000t4r
Welcome, I would do a search for K&N and you should get your question answered
2000t4r is offline
Old 12-28-2005, 04:32 PM   #3 (permalink)
ebelen1's Avatar
Quote:
Originally Posted by HenrySacto
Hi there,
Henry
Have a FIPK in my '99 and have not had similar issues. It just may be a coincidence.
__________________
____________
Edwin
1999 SR5 4unner
ebelen1 is offline
Old 12-29-2005, 05:52 AM   #4 (permalink)
Henry,
Did you install just the K&N filter, or the entire FIPK kit (which does away with the factory airbox)? Is there a chance that you disturbed any vacuum line fittings?
Andreas
__________________
2001 SR5 4Runner 4WD, Dorado Gold, 181,XXX miles
2007 Volvo XC 90 AWD V6, Silver
1995 Porsche 993, Polar Silver
aowRS is offline
Old 12-30-2005, 10:02 AM   #5 (permalink)
Quote:
Did you install the FIPK yourself? Did you have to remove the EFI fuse from the fuse box like some of the suggestions when making a deck plate mod?
Old 12-30-2005, 10:05 AM   #6 (permalink)
Quote:
Originally Posted by aowRS
Henry,
Andreas
Andreas,
I installed the entire FIPK. I'm not sure if i disturbed any of the vacuum line, but I checked and everything looked fine. Anyway, I've already removed the K&N FIPK and put the original system back. The lights are gone and will see if they come back on or not in a few days. I will return the K&N FIPK since it is well over $250.00. I will look into making a deck plate mod to get more air flow like some of the guys. Do you know anything about the deck plate mod? It is a good idea?
Thanks,
Henry
Old 12-30-2005, 10:13 AM   #7 (permalink)
Send a message via Yahoo to humanoid
Andreas,
Thanks,
Henry
It's located in our tech section. Just click on the link below for a detailed explanation of what it is. If you want others opinions then use the search feature located above... it can prove pretty handy at times
http://www.yotatech.com/~corey/tech/techpage5.htm
__________________
'99 Taco PreRunner V6 3.4L
humanoid is offline
Old 12-30-2005, 10:23 AM   #8 (permalink)
spindleshanks's Avatar
I'm not a K&N fan at all, because I'm an employee of WIX filtration, and our engineers have proven the innefectiveness of the reusable gauze type filters. On many makes of vehicles the K&N oil will contaminate the very sensitive mass air flow sensor. This will cause a decrease in fuel efficiency, a rough idle, and general driveability issues. After all, nobody knows how much or how little oil to put on one of those filters. But since it's a new kit, I'm assuming it came oiled from the factory and is probably just right.
Clean your MAF sensor with some CRC electrical components cleaner.
A Toyota tech once told me not to disconnect the battery cable to clear a CEL, because it resets all the ECM functions for the vehicle...that should give you an idea the caliber of technical skills the K&N hotline people have. What would you expect from a company that prescribes the exact same filter media for use on a worthless beat-up old '72 Ford farm truck as it does for use on your expensive, highly technologically-advanced and precision-tuned late model Toyota engine? K&N likes to talk trash about the 'paper filters' on the market, but look at your OE Toyota air filter and tell me it looks like it's made of paper. It's a specialized, highly-engineered synthetic blend that was application engineered to remove particles of a specific size, and it took years to perfect. Sorry,
I think you made the right choice getting rid of the K&N.
__________________
'03 beauty of a white Tacoma, check it out:
http://www.yotatech.com/f83/spindles.../#post50606613
"The fingers you have used to dial this number are too fat. For information on how you can obtain your own personal dialing wand, please mash your palm against the keypad now."
spindleshanks is offline
Old 12-30-2005, 11:45 AM   #9 (permalink)
surf4runner's Avatar
Quote:
Originally Posted by spindleshanks
I'm not a K&N fan... Sorry,
don't be, its allright, really.
ive had mine on for over 10,000 miles w/o any problems.
__________________
sarcasm noted...and appreciated
im with the banned
Quote:
Originally Posted by fustercluck View Post
I was traumatized. I had nightmares of trained attack tupperware beef-logs chasing me all night! Don't bend over, Fuster!!!!!
Quote:
Originally Posted by Lysmachia View Post
Just pile us nekkid in an engine bay and drizzle us with gear oil and watch the fun!
surf4runner is offline
Old 12-30-2005, 02:16 PM   #10 (permalink)
Except that it doesn't trap as manym contaminant particles of as small a size as the OE filter. How do you think it breathes better? If you really want an affordable performance upgrade to decrease airflow resistance, the best bang for your buck would be to throw away your filter altogether. Would you do that? NO? Then why would you use K&N?
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
cleaned TB, CEL, VSC trac crap on and its got a weird feelin. neliconcept 95.5-2004 Tacomas & 96-2002 4Runners 12 06-14-2008 02:24 PM
Disabling VSC & TRAC - 2001-2002 4Runner with VSC & TRAC Systems Writeups@YotaTech Electrical 0 01-11-2007 09:29 AM
CEL & VSC\TRAC Lights after Seafoam Treatment on 03' kaneman23 03+ 4Runner/GX470, & 05+ Tacomas 7 09-04-2006 08:38 PM
04 4-runner Transmisssion VSC Trac VSC off lights freemanc 95.5-2004 Tacomas & 96-2002 4Runners 8 03-10-2005 10:57 AM
CEL, VSC and TRAC on 4th gen darkstar Off Topic Talk 3 10-13-2003 10:29 AM
2009 InternetBrands, Inc.
