VIP Key FOB vs regular?
I have a 98 and trying to find the right key fob for it.
I read an old thread that mentioned a VIP version.
How can I tell if I have the VIP alarm system?
How can I determine what FCCID I need for my 98?
Thanks!
Thanks!
guys, seems to be a lot of confusion on this topic. Cant believe there isn't a thread yet with part numbers and fcc id for the different year fobs. Once I get the correct 98 fob I will post the info.
'98 was a changeover year, so there is a lot of conflicting info, all of which may be correct depending on whether early or late month, factory or port/dealer installed, alarm or not. This is why I don't answer. I can't be sure. Don't expect one fob fits all.
http://www.keyless-remotes.com/servl...-Remote/Detail
There are aftermarket equivalents around like this:
http://www.ebay.com/itm/New-Toyota-R...-/310834956365
Try putting your VIN in here to confirm: http://www.toyotapartszone.com/oem/t...191-00871.html
Nope. That's the factory system that was introduced MY1999. Different FCC number. '99+ only except maybe some late in the year '98's. But not if you have the RS3000 alarm system.
okay well I just ordered 89742-35050 fcc id hyq12bbx from the Toyota dealership. The parts guy told me this was the correct one for my 98 and this remote supersedes the old one now. I will have to see if it works!
http://www.toyotapartszone.com/oem/t...742-35020.html
Where it says "TIP".
I should have kept my mouth shut (fingers quiet).
You were correct this is the part # for my 98 PT398-07101
It just looks a little newer than what was pictured above.
The issue Im having is that either button on the remote can lock or unlock the car.
Maybe I programmed it wrong but it's super weird. And also it doesn't beep when it's locked. Perhaps I programmed it wrong but I have no idea when the car is locked or unlocked with this remote. I don't believe this is how it would be setup from the factory, would be surprising.
83yotastockR
11
11-10-2015 06:54 AM
zombie_barbarossa
10-02-2015 10:54 PM
PNW94Runner
09-29-2015 02:55 PM
