vibration question!
Old 02-21-2006, 01:05 AM
Gt4r97's Avatar
Question vibration question!
I've been lurking around this great forum for sometime now and this is my first post. My runner is a 97 limited 4wd and i'm trying to figure out why is that when i step on the brake and in full stop, i can feel a vibration in the car somewhere i cannot pinpoint. The vibration will go away once i put the car in Park and release the brake pedal.
Old 02-21-2006, 08:21 AM
humanoid's Avatar
Your rotors may be warped. I would have them either have them resurfaced or replaced entirely. That should cure your problem. BTW, let me be the first to welcome you to yotatech.com!
Old 02-21-2006, 09:16 AM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
Vibration under braking is common with 4Runners. The OEM rotors are poor such that they warp prematurely compared to most aftermarket rotors. Most people have replaced them with Brembo's. I replaced my warped OEM rotors at 65,000 miles after they were replaced once and then turned once. I have 40,000 on the Brembos with no problems.
Old 02-21-2006, 09:23 AM
ricky's Avatar
It sounds to me like he's not talking about warped rotors. Sounds more like the load from the power braking system, and the transmission being in drive, are causing a low enough rpm on the engine that it's causing the vibration.
Engine mount? dirty injectors... something crazy like that.
Old 02-22-2006, 11:42 AM
Gt4r97's Avatar
Originally Posted by ricky
It sounds to me like he's not talking about warped rotors...Engine mount? dirty injectors... something crazy like that.
Yes, i don't feel any vibration if i hit the brake when the car is moving so warped rotor is maybe not the issue(?); it happens only when i'm at complete stop and ride on the brake. It's not a vibration that completely shakes the car though. It's a slight,"rythmic", and come and go continous sound/vibration that I cannot really pinpoint where.
With regards to the engine mount, i once had an experience with my infiniti g20 and it really shake the car since the mounts were cracked. I doubt but i'll try to look into it. Dirty injectors, as far as i know when you have dirty injectors the car will drive like a crap - "rough"! Mine runs smooth and can accelerate reasonably without hesitation....
Old 02-22-2006, 11:51 AM
surf4runner's Avatar
search "brake shudder".
does it start while braking and stop if you take your foot off the brake before a complete stop? ^
Old 02-22-2006, 12:51 PM
Gt4r97's Avatar
this happens only when i have my foot on the brake and at FULL STOP and it will stop when i put it on PARK or continue driving. So i come up to the notion that there's "something" with my brakes.
BTW, before it's too late, thanks for the welcome, guys! I've learned a lot and learning more from this great forum. Thanks!
Old 02-22-2006, 01:23 PM
celica's Avatar
sounds like your idle neds to be adjusted.
Old 02-22-2006, 03:22 PM
Mr. Bob's Avatar
Sounds like a low idle indeed... How many miles on it? When was the last time it was fully tuned up? Throttle body service? MAF cleaned? de-carbonized?
Old 02-24-2006, 09:48 AM
Gt4r97's Avatar
Checked my rig's idle and is at 600 to 700, is this supposed to be low? It doesn't feel the engine is going to stall though. BTW, I cleaned throttle body/MAF 4 mos. ago. I wonder what else contributes to low idle. Is there a fix for it?
tinigunner11
08-14-2015 01:19 PM
lectric80
08-11-2015 12:02 AM
makemusic116
08-02-2015 05:23 PM
Quick Reply: vibration question!
