Vibration & growling from front end - HELP!!
Hi,
I am new to this site.
My (stock) 1990 4Runner has started to vibrate & there is a growling sound towards the front end. I can feel the vibration start at around 25-30mph but at 50-55mph, the vibration gets worse and growling gets louder. This is only in 2 wheel drive...
I've changed tires but that didn't help. The rear u-joints are a year old!
I did hear a ticking noise at the front end of the truck and then it started to vibrate when the ticking noise disappeared. I didn't get a chance to investigate. I don't know if there is any correlation with the ticking noise and vibration!!!
Does anyone have any ideas... front axles, front transalxe, wheel bearings.
One last question... If I can't figure this out, should I take my truck to the dealership where they "SHOULD" be able to diagnose the problem or an independent garage that might know a little abotu 4x4 or Toyota's?
Any suggestions, help would be greatly appreciated...
TIA... dave
TIA... dave
wheel bearings or rotors?
My truck is still awaiting its new wheel bearings, which are causing the same issues. I bought wheel bearings, seals, races, Brembo rotors and PF pads like 2 months ago I just havent had time to get started.. I would jack it up and spin each wheel and see if there is any play in the bearings... do you have manual hubs or auto??
Ditto that, sounds like a classic case of wheel bearings.
BTW- If you're a pay-to-get-stuff=fixed kind of guy - find an independent shop that does good work, and stick with em. A good independant is always cheaper than the stealers and will treat you right as a regular. Most of them are more knowlegable too - they know more than look-in-the-book...
hi,
It's auto locking hubs.
I'll jack up the truck this weekend and have a good look at it.
I hate paying anyone to fix my vehicles... but it is a little cool at the moment to work on it outdoors.
dave
dave
Flying91
45
04-11-2024 04:39 PM
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
