VERY dumb question
Old 11-04-2003, 05:19 AM
Mr.Spock's Avatar
VERY dumb question
Hi everyone,
I am a new proud owner of a 4runner 1991 sr5 (22re)4x4.
The problem is i can't figure how to remove the spare tire(under the truck).
any help will be appreciate
good forum!!
Old 11-04-2003, 05:37 AM
Co-Founder/Administrator
Staff
Corey's Avatar
A Vulcan mind meld should work for ya Spock
Actually if you lift up your rear seats there should be a long rod underneath it.
When I got my '91, I did not even know the rear sets lifted exposing the storage space under there for the jack and other stuff.
When you find the rod, there should also be a handle for it.
It might be in the very back in one of the cubby holes by the tailgate.
At the rear of your bumper is a hole.
You can see it in my pic here right above the red shackle.
Just insert the rod and then turn it counter clockwise I think.
The tire then should lower for you.
Welcome to YotaTech.
And no question is a dumb question
Old 11-04-2003, 05:48 AM
rah1420's Avatar
Okay, tell me what's the dealio on this deckplate mod.
Old 11-04-2003, 05:55 AM
Staff
Corey's Avatar
OK let me rephrase that.
No question is a dumb question, unless you did not use the first
Old 11-04-2003, 06:08 AM
waskillywabbit's Avatar
Pink Blanket Pic
Corey,
That pink blanket in the pic is just "so you!"
No question is a dumb question, unless you did not use the "dreaded flashing green button of death" first.
Now that was a nice touch!
Old 11-04-2003, 06:14 AM
Staff
Corey's Avatar
He he, it's actually not pink, well it may be now.
That blanket is about 30 years old or more.
Use to be much darker, but has faded over the years.
It's now used for working underneath the rig.
Old 11-04-2003, 06:38 AM
Mr.Spock's Avatar
A Vulcan may need help sometimes.
Thanks a lot ,i will try this tonight.
Old 11-08-2003, 09:23 AM
Mr.Spock's Avatar
Hi
It's seem to miss some hardware for raising down my spare tire.
Someone can show me a pics of what i need??
Do you know a another method??
seem to miss a rod.I have a" L" shaped rod(approx 12" lenght),a straight rod with a square shapped end with a bolt (approx 12" lenght) and a another 12" lenght rod with a flat curved end.
I do many research and did not find nothing.
any help will be very appreciate.
4runner 1991 SR5 4wd 4doors 22re
thanks
Old 11-08-2003, 09:53 AM
its2slo's Avatar
it seems like there was a longer rod hiding in the compartment you found everthing else in on my buddies runner. my dads p/u has a few rods that you connect together. i have nothing, a huge slot screwdiver does the trick but you have to get under the truck to reach it. pita!
Old 02-22-2015, 09:35 AM
Operation4Skinner1.5's Avatar
There is a 2-3 piece rod in the side compartment behind the back seats. That is what it is used for.
Old 02-22-2015, 09:48 AM
Roark's Avatar
And another....
Old 02-22-2015, 03:58 PM
TheDurk's Avatar
A 3/8" extension of 24" length or longer will engage the winch and lower the spare, if the stock tool is not available.
o2raybid
09-04-2015 12:45 PM
makemusic116
08-02-2015 05:23 PM
KBar
07-13-2015 06:01 PM
Cplmike
07-08-2015 08:47 PM
Quick Reply: VERY dumb question
