| New! Use your Facebook to securely log into this site, click logo to login |
| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Valve body this Friday
__________________
'02 4Runner - '06 XRunner Breakdancing www.BadgeYourRide.com Check this out Multi-Touch Interaction Research http://mrl.nyu.edu/~jhan/ftirtouch/ Highest Xmax 6.5" subwoofer made Total Posts: 32,218 (75.35 posts per day) [/center] [/color] Still A Neon |
#2 (permalink) |
Sponsoring Member
Did you get the URD setup tuned? The last time I saw you posting about the work you're doing, your HP numbers seemed WAY low and Gadget was encouraging you to come down and let him tune it.
The valve body work will stop the tranny from slipping and thus get more power to the wheels, but it won't CREATE more power in the engine. So the question is kinda' "what happens now when you jump on it?". If the tranny is slipping in 1st gear, then firstofall STOP JUMPING ON IT! and then yes, the valve body work will help. But if it's not slipping, and you can't break the tires loose, then the VB work won't help.
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
#3 (permalink) |
The URD kit is not tuned yet. I don't have a chance to get down there just yet. I'll hopefully be able to get down there in 2 weeks if he can do it too.
I'm in the middle of switching assignments in work, so I don't know what shift and days I will be working. As far as slipping, I don't notice anything. Unless that is what is happening when I lose power sometimes. I'll be on the throttle about half way, and it just cuts out, kinda feels like when I hit the governor.
__________________
#5 (permalink) |
I hope you can get those tires to chirp! I have to live vicariously through you guys because I can't afford those mods at this time. Keep us posted, especially after your URD upgrades have been tuned. Man I wish I could do that!
__________________
98 4Runner SR5 V6 4WD, stock with a lot of dreams for my Runner. So much to do, so little money............ Oh yeah, the elbow mod. I live in NYC. With all the bumps and potholes, I don't have to go off-roading. |
#6 (permalink) |
IT'S DONE. I just got home from IPT, and am very happy with the work done. although no tire spinnage, I am happy with the results.
John was a super nice guy who took time to explain things to me, and treated me more like a friend than a costumer. Now I just have to get some time to get to Gadget to tune out that fuel system. I know the power is there, just a matter of finding it. And the problem of it cutting out is still there. ( driving along and try to accelerate and it cuts out like I hit the governor) I am convinced it from something other than the trans though. All in all I am very happy, that is, until I get the credit card bill.
__________________
'02 4Runner - '06 XRunner Breakdancing www.BadgeYourRide.com Check this out Multi-Touch Interaction Research http://mrl.nyu.edu/~jhan/ftirtouch/ Highest Xmax 6.5" subwoofer made Total Posts: 32,218 (75.35 posts per day) [/center] [/color] Still A Neon Last edited by 4-RUNNIN' FREAK; 07-30-2004 at 11:15 AM. |
#7 (permalink) | |
Sponsoring Member
Congrats!
You've added a lot of life to your tranny! How stiff did you have him make the shifts? Quote:
When the power drops, does the engine actually cut out and stumble or just drop in RPMs and is still running? Does the "event" clear itself? If you hold your foot at the same spot, will it come back around? Is it more of an issue uphill or downhill or doesn't it make a difference?
__________________
#8 (permalink) | |
Quote:
1. He said it was the normal setup he uses for alot of 4Runners. You know it's done, But it's not what I thought it would be. I was expecting a more harsh shift. I like it though, very quick shifts. 2. I really don't know when it happens. I don't have time to look down at the gauges. It does stumble and is running. And it really doesn't come back around for about 30 seconds. I'll be going and it seems like a long time to me to get back to normal. 3. I only notice it on flat roads, as that is all I mainly drive around here. I did happen today comming down a hill on the highway from IPT. Any Ideas? Also I am going to give Royal Purple a try tomorrow a switch Mobil 1 at 3000-3,500 mile changes. I picked it up for $5/qt. Saved $6 with it on sale.
__________________
#9 (permalink) |
Almost sounds like the engine is starving for fuel ??? Maybe you need a better high flow fuel pump. Or have you changed your fuel filter lately ??
Just a thought. |
#10 (permalink) | |
Quote:
1) MAf sensor needs cleaning 2) Running too lean 3) Running too rich Chris |
#11 (permalink) |
4RUNNING FREAK, have you solved your problems? Does IPT allow you to bring the truck to them so they can do all the work?
#12 (permalink) | |
Sponsoring Member
Quote:
http://importperformancetransmissions.com/ He's got an 800 #.
__________________
#13 (permalink) | |
Quote:
Chris P.S. To answer the guys question above, John can do everything or you can bring in the VB. He did everything on mine! |
#14 (permalink) | |
Sponsoring Member
Quote:
John can certainly get the torque converter to lock-up solid, and pull ALL of the slip out of the shift points, that'd be his "racing" option (or "10" on a 1-10 scale) but it's impractical to run that way for everyday driving on the street.
__________________
#15 (permalink) |
You can only make the shifts so hard with the stock clutch packs. If you want neck braking shifts you need to have your tranny rebuilt by John and tell him how hard you want it to shift. I have a fully built IPT tranny with TC and its great.
__________________
2001 4Runner 3.4V-6 SR5 4x4 | 18x,xxx miles | Stubbs SKO sliders | Bud Built front skid | Trail Carnage belly skid | Shrockworks front | Rockware rear | Goodyear Duratracs | SS 1.2 | Detroit Locker rear | Truetrac front | 4.88s 2008 FJC TT SE 6 SPEED |
#16 (permalink) |
Just tightening the throtle kickdown cable was way more firm than I'd want to drive it everyday, that's for sure.
Chris |
#17 (permalink) |
I have my cable mid way right now...when i got john to do mine its a bit more then what he usualy does.
I dont know why you cant burn out in the dry.....i just tap the gas pedel and away she goes. John at IPT is the way to go!
__________________
-Johnny --------------------------------- '96 Taco V6 4WD Auto with 262 S2S Cams New 5VZ-FE & 3VZ-E Cams available 5vz-fe Stock CR FI Pistons NOW available! www.sea2skytuning.com Plug and Play EMS! Perfect Power, Hydra EMS, Arias, Pauter, Manley Performance Dealer.... |
#18 (permalink) | |
Quote:
Chris P.S. Johnny, you're the one that bought all my stuff, right? |
#19 (permalink) |
Hey Chris, I was laughing when i saw your name because its been a long time since i have seen you here (long time since i have been around so its prob just me
)It was a customer of mine who bought all your stuff and i installed and tuned everything up I have the same setup tho
__________________
#20 (permalink) | |
Quote:
Chris |
#21 (permalink) |
pfft and what didnt he s/c do that helps you offroad
__________________
#22 (permalink) | |
Sponsoring Member
Quote:
__________________
#23 (permalink) |
from looking at the IPT website, is about 525 how much the valve body work costs?
#24 (permalink) | |
Sponsoring Member
Quote:
If you take it out of your own truck (versus use a doner) then you'll have to factor in the cost of alternate transportation while the truck's down (rent a car?), and the cost of quick-shipping to/from the east coast (I think it ships at 15 pounds), and the cost of replacing the tranny fluid that you'll lose when you drop the pan (about 5-6 quarts). All totalled, it ends up being more like $1000 for folks on the west coast if you need it back soon. Most of that is shipping costs: Code:
Shipping from 98021, U.S.A. to 07470, U.S.A.
Rate (US$)
FedEx First OvernightŪ
8:00am or 8:30am the next business day to major cities 127.66
FedEx Priority OvernightŪ
10:30am the next business day to most cities 95.91
FedEx Standard OvernightŪ
3:00pm the next business day to most cities 91.26
__________________
| Tags |
| body, cams, upgrade, valve, washington, weasy2k |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Valve Body Upgrade for Supercharger? | Speedy | 95.5-2004 Tacomas & 96-2002 4Runners | 19 | 03-15-2007 04:40 PM |
| valve body upgrade | spaugh | General Vehicle Related Topics (Non Year Related) | 3 | 06-05-2006 07:58 AM |
| Valve body upgrade | travelinman | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 01-06-2005 09:18 AM |
| What's in a valve body upgrade? | midiwall | 95.5-2004 Tacomas & 96-2002 4Runners | 33 | 07-15-2004 08:18 PM |
| Valve Body Mods | johnboywalnut | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 06-07-2004 10:17 PM |
