valve adjustment - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-09-2006, 12:26 PM   #1 (permalink)
yotarunner96's Avatar
Send a message via AIM to yotarunner96
valve adjustment
when do you know that its time for a valve adjustment, and how much does it cost when it is time to do this task?
yotarunner96 is offline
Old 03-09-2006, 02:36 PM   #2 (permalink)
I would say when you can hear your valves clicking when the engine is warm. From what I've read it's more difficult to do on the newer engines than it was on the 22R. Well, I should say more complicated.
__________________
95.5 Tacoma 4X4, StdCab, 2.7l manual, 225k mi., stock, repainted from ugly turquoise to black.
ricky is offline
Old 03-09-2006, 02:36 PM   #3 (permalink)
alotawatts's Avatar
I plan on it when I get to about 60k miles. My owners manual / service schedule probably indicates first valve service at 100k miles...like the spark plugs. No way am I waiting that long.
Did my plugs at 35k.
__________________
01 4Runner SR5 2WD Bone Stock
00 Camry 4cyl
04 Highlander 6cyl 2WD
90 Chev S10 4cyl
Too many BMW E12's
alotawatts is offline
Old 03-09-2006, 02:41 PM   #4 (permalink)
I dont think they can be adjusted on the 3.4, but "shimmed" if need be. A major pain from what I understand.
__________________
'96 Tacoma 4x4 SR5 Xcab 3.4 5spd
ARB Rear Locker
Bilstein Shocks
Center Line Wheels w/ Cepek FC2's
Deckplate & ISR Mods
K&N Filter
JBA SS Cat-Back System
B&M Short Throw Shifter(I like it)
Alpine Sound System w/ XM Radio
boraxman is offline
Old 03-09-2006, 02:42 PM   #5 (permalink)
I've never had mine adjusted, I've got 192k. They're just starting to make some noise, so I think it's time.
__________________
ricky is offline
Old 03-09-2006, 05:05 PM   #6 (permalink)
ever since i had my timing belt changed it has seemed to make a wierd noise at idle, i dont know if is something to do with timing, or valves, or if for some reason the engine idle sound is a little bit different after the belt is changed. has anyone else noticed or expirenced this?
Old 03-09-2006, 07:21 PM   #7 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Quote:
You don't really need to adjust (shim) the valves on a 3.4L except in extreme cases.
Did you change the belt or did someone else? ....wonder if it might be a tooth off.
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Old 03-09-2006, 08:22 PM   #8 (permalink)
i took it to the stealership and had them do that with the water pump at the same time
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
3.0 Valve adjustment CoedNaked 95.5-2004 Tacomas & 96-2002 4Runners 7 10-28-2009 06:38 AM
3.0 Valve adjustment CoedNaked 86-95 Trucks & 4Runners 5 01-29-2007 08:43 PM
Valve adjustment on Rebuild Leprechan 86-95 Trucks & 4Runners 1 12-08-2006 07:33 PM
Valve Adjustment MMA_Alex 86-95 Trucks & 4Runners 10 06-30-2006 06:33 PM
3.0 Valve Adjustment dmatter 86-95 Trucks & 4Runners 9 03-14-2006 10:49 PM
2009 InternetBrands, Inc.
