VAF Problem
VAF Problem
Hi, I need some advice on an airflow meter problem. I have a 95 4runner, 4WD V6, and with the engine running, I'm reading 20 volts AC between the meter housing and ground. I've replaced the airflow meter, still same problem, and the alternator diodes test good and no AC is detectable between alternator output and ground. Any ideas would be appreciated...
theking11863
03-19-2016 09:36 PM
