Vac Guage help
Old 01-29-2006, 03:38 PM
alexander's Avatar
Vac Guage help
hey everyone, I got a quick question. I just hooked up my vacuum guage. I was just wondering if this was the right place to hook it up. I was also wondering if anyone knows if the needle is suppose to vibrate slightly while it moves at slow speeds? when i press the gas and RMP's go up fast, then it's fine, but when i press the gas slightly, the arrow kinda vibrates sometimes.
Thanks for all the help.
Old 01-29-2006, 05:14 PM
MTL_4runner's Avatar
I can't really tell from the pic what you have it hooked up to but any line which sees direct manifold vacuum would be fine to tap into. It is also common for the vacuum needle to vary a bit at idle but should smooth out (as you mention) at higher RPMs. It sounds like you are doing it correctly.
Old 01-29-2006, 05:30 PM
alexander's Avatar
yes, it is going from the manifold. Thanks for the help.
coryc85
12-05-2015 08:42 AM
jacked_72
09-14-2015 03:31 PM
sanctfy
09-13-2015 06:33 PM
May-39
09-06-2015 01:05 PM
izzmee
08-17-2015 10:20 AM
Quick Reply: Vac Guage help
