using factory fog light wires in my 01
Old 02-15-2006, 05:47 AM
lee
lee's Avatar
i have a few questions.. ive searched but didnt find exact answers.
1) what is the exact wattage of 01 factory fogs? I believe its 55W?
2) can i tap into the power and ground wires to wire up hella 500 fogs? my plan is to use splice connectors to tap in.
3) what is the functionality of stock fogs? do they come on with the headlights?
thanks!
Old 02-15-2006, 06:04 AM
JHupp's Avatar
I can answer a few question. I have factory fogs in my '01, and unless you do the DRL, and Fog mods, they will only come on with the headlights. Mine don;t seem to have very much output, they are on, but never noticeable, I am not sure in the way of voltage though.
Old 02-15-2006, 06:19 AM
lee
lee's Avatar
do i have to do both drl and fog mods? i dont mind the drl's at all.
Old 02-15-2006, 08:29 AM
lee
lee's Avatar
no one has done this??
Old 02-15-2006, 11:50 AM
surf4runner's Avatar
only w/ my DL on can i turn on the fogs, at the stem. and they go off w/ high beams on.
if you are adding significantly higher wattage lamps i would consider using the volatage supply to the fogs to operate a relay to the hellas, which are operated through a dedicated power source across the relay.
Old 02-15-2006, 11:53 AM
bamachem's Avatar
1. 55W is correct. Same for Hella 500's. Wire them up direct.
2. simply wire them in at the end where the factory fogs would have gone.
3. they only come on when you have the headlights on and then you turn on the fogs w/ the switch. do the "fog light mod" in the tech section and then you can turn the fogs on w/ the parking lights, and do NOT shut off when you flip to brights.
Old 02-15-2006, 11:56 AM
lee
lee's Avatar
sweet, so really all i have to do is use the splice connectors and connect power and ground and im all set!
Old 02-15-2006, 11:57 AM
Localmotion's Avatar
sounds right, make sure you solder!
Old 02-15-2006, 12:05 PM
nfenwick's Avatar
Personally I would use the factory wiring to activate a relay for the 550's. I would then set a separate fuse block to take to power for the lamps. This would allow the use of higher wattage bulbs, according to the gauge of the power wire. It will also take the stress off of the factory wiring. Sort of like the headlight mod.
lee
lee's Avatar
why? i cant just use regular ol' splice connectors?
like these:
Old 02-15-2006, 12:06 PM
like these:
you can, but i just feel that soldering would give you the best connection. Im no EE by any means...just my .02
Old 02-15-2006, 12:19 PM
lee
lee's Avatar
gotcha.
Old 02-15-2006, 12:20 PM
where do you plan on mounting your fogs at?
any pics?
Old 02-15-2006, 12:21 PM
lee
lee's Avatar
you can see em in my av... right on my bumper.
im gonna run the wire up to em like my old fogs i had on my crappy grille guard.
edit, ok heres a pic:
Old 02-15-2006, 12:22 PM
ohh, for some reason i thought you were mounting other fogs on there
btw: looks good man!
Old 02-15-2006, 12:24 PM
lee
lee's Avatar
thanks
Old 02-15-2006, 12:25 PM
good lookin D90 too!
Old 02-15-2006, 12:26 PM
bamachem's Avatar
splice into the oem wire w/ those crimps, then coat them w/ about 20 layers of electrical tape to keep them dry and you'll be fine. 55W is a low draw. if you ever go above that, then do another relay.
you don't want to do a 100W h3 bulb in those hellas or they'll overheat and as soon as water or snow hit them, then the glass will crack. stick w/ 55W h3 bulbs or get different lights.
Old 02-15-2006, 12:27 PM
bamachem's Avatar
chrome hoop????
Old 02-15-2006, 12:31 PM
garrett1478's Avatar
chrome hoop????
BLING BLING?
Quick Reply: using factory fog light wires in my 01
