Uses water when outside temp is cold
Old 01-20-2013, 07:30 PM
A.walton's Avatar
I have a 97 4runner completely stock 3.4 6 cylinder. I've checked the oil and its not milky. It has a constant steam and uses water when the outside temperature is 60 degrees or below. Ive racked my brain trying to figure it out and can't find anything mixing. Any suggestions on what the problem could be or something that I could check?
Old 01-21-2013, 12:11 AM
wyoming9's Avatar
Red face
Have you pressure tested the cooling system.
If it is losing coolant and it is going out the exhaust you have a either a bad intake gasket or a head gasket .
If you have a leak in the heater core you would smell the coolant in the cab:jessica::jessica:
the1998sr5
15
07-14-2020 08:35 PM
the1998sr5
27
11-17-2015 09:30 AM
rjtrials
08-06-2015 07:25 PM
Jonny246
07-12-2015 04:51 AM
Avenged
07-09-2015 07:55 AM
Quick Reply: Uses water when outside temp is cold
