URGENT : What size is front d/s hub retaining nut ?
I discovered yesterday that two front lug nuts were siezed and of course, both sheared trying to remove them.
I had never removed front wheel in the 3 months I have had truck.
I now have studs...what size is the hub/rotor retaining nut ?
(the one that is torqued to 174 ft lbs)
Many thanks..truck disabled and I don't have the right size socket
David
David
Ok,
All good. Enough clearance to remove old stud without removing D/S and splitting lower ball joint.
Used a old lug and the impact wrench to pull the new one in place.
Phew...
Pics of lift and LC rims to follow
David
Phew...
David
coffey50
07-28-2015 10:55 AM
