URGENT-Tire fitment
URGENT-Tire fitment
Will a 32x11.5 bfg all-terrain mounted on rims that came off of a 88 pickup fit on a STOCK 1994 4-runner 4x4 WITH NO RUBBING
they will most likely rub, depending on a few things... i know some people have put them on stock and havent rubbed.
but depending on the place your getting them from they should do a "test fit" for you. have them throw the tires on and run it lock to lock.
And i know that the bfg at ko is one of the "wider" at tires out there, i just test fit a set of 32 muds on my 91 runner and no rub, but if i was turning and hit a bump i would have issues.
i don't think they would rub. 31s don't and there's gotta be more than 1" of clearance. it will depend on the backspacing of the wheel also. if they used the same backspacing in 88 and 94, you should be fine.
My '88 and '94 trucks both came stock with 225/75/15 tires. Right now I have a tall set of 32" Swampers on the '88 truck and they fit fine, but my '94 truck is much lower and I'm sure they would rub. With my rigs parked next to each other there is huge height difference.
Dont think they will. I had 32x11.50 Yokos on Sr5 rims on my 94 and it was fine. On full lock there might have been a bit of rubbing but not enough for me to do anything about. Drove it for about 6 months with no problem. The only thing i can see as maybe being trouble is the front valence....no problem with that if you have a dremel though.
kawazx636
10-06-2021 03:03 PM
Ritzy4Runner
10
01-14-2012 07:11 PM
