Urgent: help on Bilstein HD Rear Shock assembly
Old 06-01-2014, 12:37 PM
madcanvis's Avatar
*urgent* Swapping out rear shocks: *urgent*
I've checked for pics and threads and not finding the answer...
Cut my old on off. No problems. Installing new Bilstein 4600 HDs.
Question:
What's the order of assembly for the top (rear)?
Or what goes above the cars attachment point?
In the pack:
2 rubber spacers
2 hardened steel washers (cupped)
1 stainless steel washer (cupped)
1 nut (obvious)
2 tapered bushings (bottom)
Not a big job I just want o do it correct and the setup is slightly different then the "foreign autoparts" replacement that was on there.
P.S. The car is on stands and is my daily driver
TIA!
Old 06-01-2014, 02:02 PM
aowRS's Avatar
Starting at the top of the shock:
- cupped steel washer (facing up)
- bushing
- shock mount/body
- bushing
- cupped steel washer (facing down)
- stainless washer
- nut
Andreas
Yotadawgjr
10
08-23-2015 10:51 AM
terminator
07-27-2015 07:13 PM
Massmayhem247
07-18-2015 05:46 AM
akaphilly
07-09-2015 02:34 PM
Quick Reply: Urgent: help on Bilstein HD Rear Shock assembly
