URD 7th Injector Kit Install
I am having the TRD Supercharger installed on Monday by my local dealer and will be installing the URD 7th Injector kit myself next Saturday..Has anyone here done this install ? If so how difficult is it ..My friend is a Mechanic and will be helping me but I was curious how the tuning works via Laptop..Any advice or personal experience would be appreciated..
Thanks, Andrew......
I would say one could install it before the S/C goes on. If you have fuel management, then just done allow any fuel to be pumped through the 7th injector....
So mokai may not want to do the 7th kit install after the dealer has installed the supercharger because he is going to have to pull the supercharger to get to the new injectors in, etc.?
Well I got the S/C on today and wow it sounds cool..It makes the truck jump right up to speed..I am getting a little bit of ping but I know how to drive it to avoid this until the 7th kit goes on..By the way it was delivered to my door today and was waiting for me when I got home..Didnt realize I have to remove the bed of the truck to get to the fuel pump..
On the way home from picking my truck up from the dealer my check engine light came on...Hmmm...Not sure what this is about but am going back to the dealer tomorrow so they can read the code and remedy the light..
Maybe a loose vacuum line..Im not sure..Any ideas off hand ?Anyone else have this happen ?
Well the code for the check engine light was the Mass Air Flow Sensor..Damn K&N filter..The S/C sucks so much air that it pulled the light oil right out of the filter and coated the MAFS..Cleaned it with MAFS cleaner and reinstalled..Cleared the code and am putting my stock air box back in..Think I might do a modified Deck Plate mod..Think I will run a piece of tubing from the front of the stock air box to the grill area so that it gets true cold air and not engine compartment air...Im going over ideas and will come up with something cool..
That doesn't sound so bad. Try out the tru flo air filters from www.burtmanindustries.com you might need to call and order for your specific truck.
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
7th, injector, install, installation, installing, instructions, kit, kits, mod, modifications, mokai, tacoma, trd, tuning, urd
