Upper ball joint removal
Old 05-29-2014, 03:04 PM
j-man's Avatar
how do i get that darn thing out? Im putting a set of camburg's on, but have to get the stocker upper joint out first...
Old 05-29-2014, 06:25 PM
BigWavePaul's Avatar
A cheap pitman arm puller from HF modified to accept a 1.75" opening will do it.
Old 05-30-2014, 04:40 AM
Nelsonmd's Avatar
You can do it pretty easily with a harbor freight 3-jaw puller too, though mine has been modified to make it alot stronger. I did this with my harbor freight 3-jaw puller and it went like butter.
Old 05-30-2014, 05:18 AM
Jomoka's Avatar
You could also free/rent a ball joint press from Autozone. It's a bit of a PITA, though. Those things really don't want to move.
Old 05-30-2014, 06:34 AM
offset442's Avatar
used a combination of a screw type ball joint press and an air hammer for some extra mojo, works good, better yet find a buddy with a shop press, i used a 12 ton and they where still a hard press, you will need the ball joint adapters from the screw type press to use as receivers on the bottle jack press other wise you can damage stuff trying to use sockets and bearing bits.
Old 06-01-2014, 12:57 PM
2Whlin's Avatar
I purchased a Harbor Freight Ball Joint Seperator and it was piece of cake. May take a couple of whacks with a heavy hammer, but it should just pop right out.
Old 06-01-2014, 05:13 PM
Jomoka's Avatar
There's taking the shaft out of the upper arm, which is fairly easy.
Then there's pressing the base of the ball joint out of the steering knuckle/upright, which is a lot more difficult.
Swim
9
01-04-2016 10:47 AM
09-04-2015 09:27 AM
krimsonone
07-29-2015 11:53 AM
coffey50
07-28-2015 10:55 AM
ksmudrunner99
07-21-2015 05:33 AM
Quick Reply: Upper ball joint removal
