| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Upper Ball Joint
__________________
1999 4 Runner 9.9 sec 1/8 mile on 7 psi and fuel injectors only (NO Alcohol) weak tune! TRD Supercharger, Alcohol Injection, Walbro fuel pump upgrade, Custom 2.5" stainless exhaust, 3" Tundra/LC Coil Lift, 1.5" 4Crawler BL, 305/70/16 Mickey Thompson MTZ's... Next: HID Bi-xenon Conversion, Tundra brake upgrade... |
#2 (permalink) |
make sure you do all of them, upper, lower, left and right. then alignment. you'll be sorry when you have to do one of the others after you do the one that needs it. you'll need a coil compressor.
#3 (permalink) | |
You won't NEED to take the UCA off but it does make it easier.
__________________
"Prepare for the worst, hope for the best" 2002 Tacoma Doublecab - "TURTLE TACO" Just a bunch of bling on a truck...
Quote:
#4 (permalink) |
Could someone tell me the indicators and symptons of a worn out and or ball upper ball joints or ball joints in general?
__________________
02 4runner conversion complete! |
#5 (permalink) | |
Quote:
I don't think you need a spring compressor. Especially if you are taking the struts off anyway to remove a top plate spacer.
__________________
99' 4Runner SR5 5spd 3.4L Sonoran Steel 7.1/7.2/OME891 Previous Vehicles: 1985 4x4, 1990 4Runner |
#6 (permalink) | |
^ Right on about not needing the coil compressor. Unless you put the spacer IN your coilover
![]() A balljoint is worn out when you start to get "play" in it when grab the arm and shake it. It may also make some noise as it gets worse.
__________________
Quote:
#7 (permalink) |
I didn't pull the UCA but I did pull the spindle off completely...easier to work with. After that I used a really big vice w/ cheater bar and a piece of tube that fit right around the base of the ball joint. Pressed it out and then pressed back in. Just take your time and make sure it goes in straight.
__________________
Lance 2001 4Runner Limited 4X4 -- 315/75R16 MT/Rs | MT Classic IIs | Dual ARBs/4.88s | (F) 5125/Tundra Coils (R) 5125/LC Coils | 4Crawler 1.5" BL | Aisin Manual Hubs | Slee Sliders | Sonoran Steel Rear Bumper | TJM T-15 w/ Warn M8000 2004 Land Cruiser -- OME Medium Lift | Nitto Terra Grapplers |
#8 (permalink) |
Well, thanks for the input... Got it done yesterday. I did not remove the spindle or the arm to do it. It was a little bit of the PITA and took about 2 hours to disassemble and reassemble, but was much better than my quoted 330 bucks at the mechanics. I also put in my rear 7 wrap coils, took out a top plate spacer and removed the rear conical bumpstops. Not bad for a days work and 5 hours of mess. Getting it aligned today hopefully!
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| How to replace upper ball joint | Localmotion | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 02-04-2007 06:46 PM |
| replacing upper ball joint | jeepboyny | 86-95 Trucks & 4Runners | 14 | 10-06-2006 07:18 AM |
| New here and need help with upper ball joint | Stal | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 07-15-2006 08:12 AM |
| Upper Ball joint mystery? PLEASE HELP! | SuaveGato | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 06-16-2006 10:55 AM |
| upper ball joint | Godzilla | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 07-08-2004 01:12 PM |
