Upgrade SS1.2 rear help
Old 06-11-2014, 06:55 PM
FJHammerHead's Avatar
On first major vacation in the 4runner. When I put on the cbi rear bumper there was a little sag. Now that it's loaded up there is about a 4" drop. Out here in Wyoming it has bottomed out many times. Obviously I'm going to have to upgrade when I get back.
I figured there might be an offroad store in Utah that we could stop by on the way home. Will I need to upgrade springs along with the springs?? Any ideas on what to get?? I have sent 4cawler an email but have not heard back yet.
Thanks
Old 06-11-2014, 07:49 PM
KZN185W's Avatar
One option would be to install helper air bags inside the rear coil springs. if you need more support, just air the bags up
Old 06-11-2014, 08:10 PM
BlazeRunner's Avatar
Look into OME 851 or 861 for the rear with that much weight. That should level you out or even slight rake.
http://www.toyota-4runner.org/3rd-ge...-vs-861-a.html
Old 06-14-2014, 08:23 PM
I will looks into those. I think these bilsteins are shot so I will have to replace those too
Old 06-15-2014, 03:53 AM
aowRS's Avatar
Have you contacted Sonoran Steel for suggestions?
Andreas
Old 06-15-2014, 06:14 AM
I did email them but have not heard back from them. I didn't here anyrhing, so I posted here. They are probably too busy
Old 07-12-2014, 10:21 AM
sschaefer3's Avatar
I never got your e-mail. If your shocks are shot replace them, the black shocks will work a lot better with all the weight, I would use the air bags because when your unloaded you can adjust the ride back to smooth. With those other coils it will ride rough unloaded.
06-01-2021 01:51 PM
rondogracing
Engine Swaps
16
08-24-2015 03:02 AM
Nailit69
Diesel Swaps
07-21-2015 05:28 PM
rondogracing
07-14-2015 07:00 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Upgrade SS1.2 rear help
