Turning Left and a POP!
Old 01-29-2005, 11:26 AM
kenfused's Avatar
Hello,
For about 2 months or so, whenever I make sharp Left Turns or U-Turns, I get a single "pop" type feel that seems to come from the Front L wheel area...
I got new Bilsteins last year, and new tires last year, new brakes last year...
Nothing else...
Any ideas what It could be? Normal Left turns (90%) don't cause the problem...
What should I consider?
BTW, it's a 1996 4Runner 4WD
Old 01-29-2005, 11:36 AM
93ToyKid's Avatar
I have a 93, and it does the same thing. No idea what it is.
Old 01-29-2005, 11:50 AM
trx125's Avatar
Cv half shaft if it is 4x4 may be going out
Old 01-29-2005, 11:58 AM
Co-Founder/Administrator
Staff
Corey's Avatar
Can not help the first post, but yours is caused by a dry steering stop.
Do a search on the forum for steering stops, and you will see how to lube them to prevent the popping noise.
Old 01-29-2005, 02:31 PM
93ToyKid's Avatar
Yea I already put grease on that a long time ago. This noise is something different, but thanks anyway. For now I just live with it since it only does it backing into my driveway. By the way, I love your website Corey. Your Runner is AWESOME!!
Old 01-29-2005, 02:45 PM
Sponsor
Tofer's Avatar
there are a couple other treads about this pop, its normal.. my 94 does it too
Old 01-29-2005, 03:20 PM
MTL_4runner's Avatar
Originally Posted by kenfused
Hello,
Nothing else...
If you make a sharp turn in 4wd you will definately hear a pop from the CVs binding a bit.
Mine does it too....just pull it out of 4wd for the sharp turn and re-engage after.
If you were not in 4wd, you definately have something else binding.
Old 01-29-2005, 04:07 PM
smr4runner's Avatar
Hello,
Nothing else...
How loud of a pop is it?
I agree with MTL_4runner. If its loud you might want to check your CV axle.
Does this pop occur after the turn and you straighten out your wheel or when your going into a full turn?
Old 01-31-2005, 09:59 PM
kenfused's Avatar
Seems like it happens as I'm doing the turn, right as I pass the angle needed for a normal 90 degree left turn and get to the 120 degrees of a 180 degree U-Turn.
This happens when I'm NOT in 4WD (which is most of the time)
Old 01-31-2005, 10:57 PM
User 051420's Avatar
I got this same soud popping a while back. I'd go to make a hard left, and I'd get a loud pop out of the right side. It had something to do with my alignment...prolly my bad CV too.
Old 02-01-2005, 08:29 AM
kenfused's Avatar
Thanks for the replies...
Just for a newbie...
What does CV stand for and where is it?
And where is the STeering stop that I need to lube?
https://www.yotatech.com/forums/show...=steering+stop
Old 02-01-2005, 08:58 AM
Runner4's Avatar
Check your sway bar bushings. This is easy to check and cheap to replace. I had the same popping, and it was caused by the ruptured bushings slipping when the body rolled a little bit. At first mine was only when I made a left turn, but it eventually ruptured both bushings, and I heard the popping when turning either direction.
Old 02-01-2005, 09:11 AM
PirateFins's Avatar
CV stands for Constant Velocity (Joint). It is the half shaft that connects the wheel to the diff. One per wheel.
the steering stops are on the wheel hub backing plate, front and rear of the wheel.
Look here Wheel pic That is a pic of a member here's wheel. He has the steering stop circled. Ther is one on the opposite side of the wheel just like it.
Old 02-03-2005, 10:19 AM
kenfused's Avatar
Thanks for the pic!
How do I lube this joint?
What kind of lube do I use?
Thx!
Old 02-03-2005, 06:57 PM
Keggo's Avatar
Thx!
Sorry... I'm immature. In all seriousness you could probably just use some all-purpose grease? I don't know... I've learned to live with that terrible popping when I turn sharp.
jasonty
41
12-23-2018 01:00 PM
mskalmus
05-28-2017 07:51 AM
Shoua
13
05-22-2016 05:19 AM
Hiluxtrucha
07-22-2015 10:00 AM
Hamonacracker
07-17-2015 08:33 AM
Quick Reply: Turning Left and a POP!
